08-09-2015, 08:41 PM | #1 |
2" 1972 C10 Coil Spring Lift Suggestions?
Looking for a nice cheap 2" lift to make my black beauty look that much meaner. 1972 C10, 1/2 Ton, LongBox, coil springs. Any recommendations guys?
Posted via Mobile Device |
08-10-2015, 03:02 AM | #2 |
Re: 2" 1972 C10 Coil Spring Lift Suggestions?
The front you can run 1 ton springs or do the 88-98 lift spindle swap.The rear i have no clue on if you have coils but if its leafs you can get a longer shackle.
08-10-2015, 08:26 AM | #3 |
First you have to flip the shackle. On the these trucks at least, the shackle hold the spring above the shackle. For 1" or 2" a block is best for leaf springs. No change in spring rate or binding.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-10-2015, 01:31 PM | #4 |
Coils in both the rear, and front.
08-10-2015, 01:34 PM | #5 |
I was maybe thinking of doing something more along the lines of blocks, as there is coils in the front and back.
08-10-2015, 03:44 PM | #6 |
Blocks would be unstable for anything other than normal street driving. Is this a 2 wheel drive truck?
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
08-10-2015, 11:16 PM | #7 |
With rear coils you need taller springs,You can't use a block to lift it in the rear the axle is on top of the truck arm a block would lower it.
08-11-2015, 12:12 PM | #8 |
