![]() Join Date: Nov 2013
283 out of a 67 c10 swb
I have this 283 that I have stripped out of my 67. It set outside and locked up on me. I pulled the oil pan and everything looks good underneath. The PO put electronic ignition, and an intake off of a 305 on it, but from the heads down its still all original. You can have the aluminum bellhousing that's on it also. I just stuck it on there to protect the clutch while I stood it on end to pull the pan off. $150
![]() Join Date: Sep 2007
Re: 283 out of a 67 c10 swb
would you sell the ramhorns seperate or are they cracked?
1967custom |
No they're not cracked but I can't separate right now as its for sale here locally also. If the ad I have here locally runs out and no interest you'll be first on the list for them. Thanks
sounds good
1967custom |
bump
I let the cylinders soak in diesel for a couple days and it freed the engine up.
sold
