08-10-2015, 10:48 PM | #1 |
Fuel Lines
Hey guys so i have a 72' c10 with a 350, what's the best fuel line? right now i have rubber lines, or a type of rubber lines, and someone said that "that's the best way to burn a truck to the ground" are they right? and if they are what is the best kind of fuel line that'll fit right on without much finagling? thanks guys!
08-11-2015, 09:42 AM | #2 |
Re: Fuel Lines
Standard rubber line from the parts store isn't good with the ethanol in fuels today. You can buy good rubber line that will last a long time, but its pricey. The factory uses small rubber pieces to connect steel tubing for the fuel lines, and that is what most people prefer. In particular where the fuel line goes from the fuel pump to the carb, you don't want rubber laying in the engine heat.
I did my entire fuel system with AN fittings and expensive synthetic rubber hose that is designed for ethanol. I ran the hose way from he engine to my regulator on the wheel well, so it doesn't lay on the engine. I got everything from Earl's via Jegs. I think to do from the tank to the carb cost me about $400.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
08-11-2015, 02:24 PM | #3 |
Re: Fuel Lines
Personally, I prefer little rubber as possible. Need one between frame and engine to absorb movement & vibration of course. Never EVER run rubber fuel hoses over exhaust manifolds. Be absolutely sure the steel line ends are flared to keep the hose from slipping off. Spring band clamps are preferable to worm gear types.
08-11-2015, 03:47 PM | #4 |
Re: Fuel Lines
I prefer the high pressure plastic type line that Dorman makes and sells at O'Reilly's. Probably others. It comes in a 20' roll, will handle high fuel pump pressures (modern fuel injected no problem), and it's easy to route. Just have to install clamps "often" to keep it from moving/chafing. Then go to ACE or another and get barb to M.I.P. fittings and good to go. Did my whole Chevelle including fuel regulator/filter to my LS motor for less than $100.
"Life is too short to drive a boring vehicle". Later, Wayne |
08-11-2015, 08:37 PM | #5 |
Re: Fuel Lines
I made my own fuel lines using a cheap tube bender from ebay and (lots) of Poly Armor tubing from NAPA. It took "lots" for me since I couldn't get it just right.
When I later built a work bench and got off the floor, it was pretty easy to bend it the way I needed (bending on the floor wasn't easy). I bought a flare kit from Sears (Craftsman) and with my bench vise, bubble flaring the ends was a breeze. I bought a pre-bent stainless line for over the engine but I don't think it will line up with my carb. I'll just make my own using my flare kit (does double flares too) and bender. So, take off your old lines, mimic those with new line, and just trial and error it. The hardest part was the 3/8" line from the tank through the cab floor, but I got it right on the 3rd try. I bought a brass 3/8" to 5/16" transition fitting from Summit Parts to join the in cab line to the under frame line. I put it all together with rubber fuel line from NAPA and Advance Auto, there is less than 6" TOTAL of rubber fuel lines the whole way now. If you need any help, drop me a PM and I'll hit you with my phone number. *I reused my vent lines (1972 truck with EEC) after washing those out with Krud Kutter phosphoric acid. |
08-11-2015, 08:38 PM | #6 | |
Re: Fuel Lines
08-11-2015, 09:32 PM | #7 |
Re: Fuel Lines
Thank you all for your reply's! I really appreciate all of them!
08-12-2015, 11:34 AM | #8 |
Re: Fuel Lines
Good posts Ten ring.
I would only add a little trick. Take off the old line and run a length of string along it while carefully following all the bends. Now straighten the string and measure it. You now have the total length you need of straight line before it's bent. |
08-12-2015, 11:52 AM | #9 | |
Re: Fuel Lines
08-12-2015, 01:19 PM | #10 |
Re: Fuel Lines
Again thank you for the replys, but I guess I should have been more specific. haha I meant from the pump to the carb, from the tank to the pump is good and all metal, but the line from the pump to the carb is rubber, the closest it gets to the manifold is probably 4-6 inches, I don't know i just want to change it just to ensure nothing burns...but thank you all!
08-12-2015, 03:10 PM | #11 |
Re: Fuel Lines
Hahaha. Oh ya, we are CRAZY detailed around here! LOL
I'd still make my own. Here is exactly what I bought. Craftsman Double Flare kit. (www.sears.com) Poly Armor tubing (NAPA store) Rigid tubing cutter (amazon.com) Put the fitting on BEFORE you flare your ends. Seriously, make your own and saver yourself the hassle. |
08-12-2015, 09:05 PM | #12 |
Re: Fuel Lines
Mine ended up being exactly the same length as the longest piece of brake line they sell at the parts store. 6 feet I believe.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
08-12-2015, 11:36 PM | #13 |
Re: Fuel Lines
thanks in the ten ring! I'll definitely send you a PM if i run into any problems!
08-13-2015, 12:14 AM | #14 |
Re: Fuel Lines
Would someone mind posting a pic of hand made fuel lines from pump to carb that includes regulator and pressure gauge?
Thanks, Jeff |
08-13-2015, 01:50 AM | #15 |
Re: Fuel Lines
I bent my own steel line in about an hour. Total cost was about $10.
08-13-2015, 02:39 AM | #16 |
Re: Fuel Lines
Pretty sure at this time that "fuel' lines are compatable with current fuel. fuel lines should not sit on the shelf for more than two years. Most turn over every 3 to 6 months. So anything not compatable with alcohol fuel mixtures has been rotated through the supply system by now.
fuel lines are marked with the date of manufacture in units of a quarter and the year, so a fuel line marked 2-15 would have been manufacured bettween april and june of 2015. Old dry rotted ones are the real fire hazzard ANY fuel line should be replaced every 2 years Yes even the stainles flex lines....two years. pretty does not count. a good choice for replacement are the 50 psi plus hoses typically used in Fuel injection systems. yes, more expensive.but we just talked about burning your truck down Last edited by mike16; 08-13-2015 at 02:47 AM. |
08-13-2015, 09:01 AM | #17 |
Re: Fuel Lines
I went this route with my big block. Check Jegs for the small block application.
http://www.jegs.com/i/Edelbrock/350/8124/10002/-1
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
08-13-2015, 10:07 PM | #18 | |
Re: Fuel Lines
08-14-2015, 12:07 AM | #19 |
Re: Fuel Lines
08-14-2015, 03:56 PM | #20 |
Re: Fuel Lines
Rubber fuel lines should be checked every couple years. I think Aeroquip recommends replacement between 5-10 years for their stuff. Everyone goes overboard with the whole, "your truck will burn to the ground" thing. No, it's not ideal to use rubber, no, I wouldn't use it, and runs longer than a few inches to connect two hard lines aren't recommended by any professional affiliated in the automotive industries.
Do it once, do it right, and enjoy your truck for years without unnecessary maintenance. If you're skills aren't good with bending hard line, it's cheap enough to buy some and practice. If you get good enough friends may want it done, and you can easily recoup your paltry investment in hard Aeroquip |
08-14-2015, 07:02 PM | #21 | |
Re: Fuel Lines
Ought not to be too critical of others unless you been there and clearly...you have not. Going overboard? rubber that is compatable with the fuel is ok to use. It does need to be inspected. the problem is that the line fails on the inside too and some times faster than it appears on the out side. ditto for stainless braided lines. Do it once? no. do it as often as nessesssarry to ensure your vehicle does not burn down. And if your vehicle burns down and causes other damage, your liable for that expense too. How does Aeroquip know the circumstances or the envirionment under which your hose is working. I say this because Its happened to me and I seen it happen to others. Quit some time ago there was an article about this very issue in POCI monthly magazine. You go ahead and take the risk but dont pass on that as good advice to others.Plattitudes and mantra's dont put the fire out. Might want to keep your good advice to your self. Nobody wants to loose thier vehicle to a fire. there's no up side. replace them every two years. nuff said here. shall I bring some marshmellows? |
08-14-2015, 09:09 PM | #22 |
Re: Fuel Lines
Yes Mike16, people do go overboard with it. Telling someone there's a fire hazard is an appropriate warning. Sarcastically exclaiming it will burn to the ground is juvenile. Yes, I've seen vehicles catch on fire due to fuel leaks. Yes, I've also seen vehicles use rubber hose for years and never burn down. The phrase do it once, was referring to hard line so you can stop manipulating what I'm saying.
Aeroquip gave a general guideline for line replacement, I repeated it. Of course conditions affect lifespan. Furthermore, this hasn't been the first time you've sought out something I've posted, or others on this board and rebutted using a butchered English language and questionable phrasing. Frankly, I'm tired of your commentary as you use no tact while you bark commands and accusations. Since we're handing out suggestions, I'd certainly urge you to try spell check and possibly a college level English class. Moderators do what you will. |
08-14-2015, 09:40 PM | #23 | |
Re: Fuel Lines
The 45 year old rubber fuel hose was just recently replaced on my truck. And guess why...because the steel line rusted out so I replaced everything.
08-15-2015, 05:05 PM | #24 | |
Re: Fuel Lines
Your opinion expressed from your state will not put out a fire under the hood of someone elses vehicle in another state. So look at your own advice from that perspective. And attacking others who challange your advice. Why not just stay focused on the subject of the thread. I am certain based just on your advice and deffensiveness about the realisation you give unsafe advice that you have little or no idea about what your talking about and its best to let others talk about what they know bout. It does no good to back peddal or put new and improved spin on irresponsible statements about other people to divert attention from your "opinion". What exactly are you implying that I am smoking when I give advice that people should change thier rubber lines more often. Are you implying that my judgement is impared because I reccomend caution based on my observation, and experience? and of course you attribute reccomendations to vendors rather than take responsability for your own statements. Again I ask how Aeroquipe knows the circumstances under which there hose is being used? I know the answer to this . I'm just pointing out the falacy of your arguement and how you back out of it by attributing it to others. I for one boldly take full responsability for all that I say and blame nobody else. and finally. once again you dance around the irresponsability of your expressed opinion to attribute my response to attacks on you and others. Nice try. I expressed my opinion that the hoses should be replaced every two years and you expressed your opinion that because of my sugestion, I must be smoking something. And in your opinion I have done this to you and others on different occassions? Again You avoid addressing your opinion directly and claim this time and other times that I "rebutted" others as well using butcherd english. Again false on its own but also convienently attacking me and it seems you cant go it alone and must drag others into the Rebuttal. Accept the fact that my advice is good and err's towards safety and is not the opinion of a person smoking what ever your implying. If you knew what you were taling about and did not always blame others you would agree with my advice and not attack me. The only good advice you have given is that I use spell check. I wont take it. as for the english classes....well the suggestion is yours but since I manipulate what you say .....I probably have more degrees than you do. Its not relative to my contributionon this forum. But my decades of experience are. Some may call it butcherd english,others call it the kings english. Its funny that you claim I manipulate what you say. That would suggest your English is butchered too. and there is no way i would directly or indirectly allow the advice you gave to be stated or taken seriously if it were to be attributted directly or indirectly to me. If I have the power to manipulate statements. it would be good for all. I would never accuse someone of smoking something as a rebuttle. a deffense or to insult them to win an arguement. Facts win arguements. insults show the hollowness of a lame deffense. I am sorry you feel I am seeking you out to attack you. Frankly I cant imagine seeking your advice or opinion on anything.or expressing it through some form of manipulation. In fact I would suggest that its the other way around. when you attribute my suggestion to drug use? It is, as you say simply a rebuttle to irresponsible statemments disregarding safety. You are allowed that, But you can also descide if I am allowed that same privelege? You can rebutt, attack and imply but when I simply reaffirm my previous statement, I am wrong, on drugs manipulating what you say or seeking out yourself and others and attacking you? Clearly your imagination of me and who am has run wildly out of control. and calling on moderators to assist in your deffense? Fair enough, you need it. but wouldnt it be better all around if we stayed on the subject regarding rubbe fuel lines. Stand your own ground. Explain how you came to the conclusion that I am smoking something because I suggest that rubber lines should be replaced every two years. Do you have any idea where that suggestion even comes from? You could have challenged me on the source of my suggestion but skipped all that to attack me personally You stated/implied it. I dont see the connection. you prove it. Dont attack what I suggested, dont attack me any further, just explain to everybody else how you came to the conclusion that my reccomendation suggests I'm smoking something. My suggestion that err's on the side of safety, for good reason, implies that I'mon drugs? you explain it. You dont even know me. You know nothing about me. every two years........take it or leave it. I wont respond further so as to avoid this deteriorating any further but I would like you to explain how replacing rubber fuel lines every two years suggests I'm on drugs. explain it to every one else. Last edited by mike16; 08-15-2015 at 05:29 PM. |
01-01-2016, 10:55 PM | #25 |
But Found Her 25yrs Later!
Re: Fuel Lines
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
