Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-10-2015, 11:21 PM   #1
rcnutt
rcnutt's Avatar
voltage drop problem
I have converted my sbc to a 3 wire alt and a hei from points. My voltage is dropping from 12.35 to about 9.40 when cranking. Then back to 12+ in the run pos. Any thoughts? Thanks
rcnutt is offline   Reply With Quote
Old 08-10-2015, 11:29 PM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: voltage drop problem
It does take some voltage to crank an engine over...then once its going the alternator maintains the battery from there. A voltage drop while cranking is normal...long as it doesn't stay that way when the engine is running.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-10-2015, 11:43 PM   #3
BigDan3131
BigDan3131's Avatar
That number seems low, is that alt putting out enough? Don't you have to wire an HEI directly to a 12v source and get rid of the resistor and fusible link?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-11-2015, 12:21 AM   #4
Captainfab
60-66 Nut
I agree. Plus the available voltage without the engine running and when cranking doesn't have to do with the alternator but the battery. Unless of course the alternator is not maintaining the battery.
Old 08-11-2015, 12:27 AM   #5
jtrichard
Where are you checking the voltages at ? what size are your battery cables? and did you run new wire (what size) to the HEI?
jtrichard is offline   Reply With Quote
Old 08-11-2015, 08:22 AM   #6
corvettejim1968
corvettejim1968's Avatar
how is your ground? i like a good ground to the frame and to the body.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 08-11-2015, 08:51 AM   #7
vince1
12.35V is between a 50% and 75% charge. Should be 12.65V.
http://theamcforum.com/forum/battery...opic52935.html
With the vehicle running I look for between 14V and 14.5V across the battery posts.
vince1 is offline   Reply With Quote
Old 08-11-2015, 01:57 PM   #8
par4tom
12.3 to 12.6 is a standard resting voltage...14.1 to 14.3 is good voltage with the vehicle running. Newer batteries should rest about around 12.5 or higher.
Although a slight drop in voltage is normal during cranking, getting down below 10 volts is definately a problem and needs to be checked out.
Put a good trickle charge on that battery overnight to see if the battery can be resurrected. If not, go and get a new battery. I just got an Optima red top for $153 from Summit including shipping...Autozone, etc has good batteries for less than $100 bucks. Heck, I think Wal Mart does too!
Also, make sure you get something with 800 Cold Cranking amps...or more. Anything much higher than that is overkill...
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 08-11-2015, 10:11 PM   #9
Bigdav160
Bigdav160's Avatar
I've got to disagree with you Tom.
Although a hydrometer is more accurate, 12.3 volts is a discharged state. Close to 50%.
Starting at 12.3 volts is going to result in a lower cranking voltage. 9.6 volts is considered acceptable but higher is better. Even the best, freshest, batteries usually cannot support 11 volts or more while cranking.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-11-2015, 10:31 PM   #10
par4tom
Thank you Dave...I should have been a little more specific...a good battery that is reasonably fresh should be 12.5 to 12.7. Below 12.5 is showing a battery that is perhaps getting tired. 12.3 to 12.5 is probably a bit tired... But should still be usable. Below 12.3 and there could be challenges under high draw conditions.
Of course there are many other variables... Strength of connections, conditions of cables, impedance, gauge of cables, starter amperage draw, how long you are cranking it etc... I was trying to give some help on resting battery conditions.
Best,
Tom
My Build Thread
