Pinion angle question
I have a 72 c10 with a ford rear end. The pads are not welded to the axel tube. I need to weld the pads on but I'm not sure what to set the pinion angle to.
My plan was to set the truck to ride height (air bags) and align the pinion with the drive line. Next I was going to tack weld the pads on before removing for finish welding. Does this sound reasonable? Thx Dennis
======================================== Dennis 37 ford coupe 68 short narrow 72 short wide |
Re: Pinion angle question
One piece drive shaft? You want the output of your trans to be parallel with your input on the rear end.
For example, if your trans is pointing down 3 degrees then you want your rear end pointed up 3 degrees.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#3 | |
I did read that it should be parallel to the transmission to minimize vibration but had forgotten about that. While reading is good it is no substitute for experience so thank you for your input.
