Old 08-12-2015, 03:30 PM   #1
88Stanger
88Stanger's Avatar
4x4 steelie rims on all 4 of lowered truck
Using 4X4 Truck (6 Lug) rims and for my rims. I believe they (4) are 15x8. My question is will these work up front (the 15x8)? I have searched to see if anyone has done this and found nothing directly stating this has been done. I am painting them this weekend and want to make sure they will work. (front disc conversion going on with 2.5" drop spindles)
Also, suggestions for center caps? I have the 4 from the 4x4. The only issue is two of them have holes for the manual front end locks, so I picked up two other closed ones, so now I have 4, but is there another choice? I bought some moons with bowtie on them, but they will not fit.
Thanks for any help.
88Stanger is offline   Reply With Quote
Old 08-12-2015, 03:38 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: 4x4 steelie rims on all 4 of lowered truck
I think people have used vw hubcap wheel clips for using a rally wheel car center cap/baby moon on wheels that don't except them. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 08-13-2015, 09:38 AM   #3
They work where ever an 8" rallye works. I use them with drop spindles.
Old 08-13-2015, 11:21 AM   #4
Pick
Pick's Avatar
Im pretty sure I have the wheels you're talking about on mine......and yes, they work well. I had stock 1/2 ton hubcaps on them when I got them.
Before the drop spindles and disc brakes....(4 wheel drums)
After the drop spindles and disc brakes...(4 wheel discs)
I have more pictures of wheel fitment in my build thread.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 08-13-2015, 11:59 AM   #5
michael bustamante
michael bustamante's Avatar
i put my blazer 15X8 rallies on my truck after i installed my mcgaughy drop spindles and 6 lug rotors. they fit and i could turn no problem but the inside lip was pretty damn close to the steering end link and at full turn was kinda close to the lca. but theyll work no problem.
1967custom
michael bustamante is offline   Reply With Quote
