Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-12-2015, 06:24 PM   #1
Jim Timber
Newbie C65 owner
Hi guys.
I just found this place looking for info on my new to me 1975 C65 former pumper truck. The previous owner took the tank and pump off, so it's missing the carrier bearing and I'm going to cut it down and put a dump box on it anyway, so the frame's getting cut down shortly and I'll deal with the driveline then.
30,011 miles on it. 366ci, 5x2 manual, 10R20's, 6.5 and 8.85 rear end ratios
Just thought I'd say hi.
That's my FIL in the photo. He was looking at the rocks in my taconite tailings. Old fart keeps making off with my driveway!
Jim Timber is offline   Reply With Quote
Old 08-13-2015, 12:25 AM   #2
mrolds88
Re: Newbie C65 owner
Hi Jim, Looks like a fun build.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 08-13-2015, 12:45 AM   #3
Jim Timber
Should be.
The guy I bought it from was going to do the conversion and add it to his fleet, but ended up finding an International 5yd truck that needed some paint and got it. This one has been sitting for about a year since the driveline was dismantled, so I might need to go through the carb to get her running right.
P.O. has a 5yd box and all the makings of the wet kit I'm buying from him, and he's got a big payloader to set the box with at his place - he's agreed to help with that when I get the chassis ready and running. I can drive it over and we can mount the bed (it's on a subframe, so that should be easy), then I'll drive it home and get the hydraulics working. I'll be able to raise the bed with my tractor to gain access to the frame.
How hard are the frame rails to drill on these? I'm guessing cobalt bits and some cutting fluid to pilot? Do I need to rent a mag drill, or will I be ok with a regular 1/2" and silver-deming's? I'm a machinist, so this isn't too far out of my wheelhouse, but I haven't put a file to the frame yet to see how hard it cuts (it's at my land about 110 miles from home).
This weekend I hope to get the rivets cut off and at least free the spring hangers from the frame. I'm just going to grind them and punch them through.
Old 08-13-2015, 02:27 PM   #4
mrolds88
Dont know how god/bad it will be to drill. I wouldnt think too bad. I'd start with a good bit and cutting oil and see how it went. Your first hole should give you a good idea. As far as your rivets go, I would take a cutoff wheel and put an X on the rivet heads then pop the heads off then a 1/4 at a time. If you cant get to them with the cutoff, drill them down to the base of the head and drive out. I usually replace them with a bolt one size up. That way you know the bolts are tight in the holes.
93 K2500 xcab 6.5TD
Old 08-13-2015, 03:05 PM   #5
Jim Timber
I've cut rivets out before, and planned on using a cutoff wheel. I don't feel like driving my acetylene tank 2 hours in the back of the Tahoe, and I'm less enthused about driving it on my open trailer.
Are these half inch rivets, or are they bigger? I've read the current upfitter's best practices, and they say to max holes at .750, but then say the rivets are .620 (5/8") in a .660 hole and that doesn't make sense to me unless they mash the rivet to fill the loose side?
I don't recall how big the rivets I cut out of my 1/2T's were. It's been a few years since I moved anything structural on a C-frame.
Old 08-13-2015, 05:03 PM   #6
mrolds88
On 1/2, 3/4, 1 ton stuff they used 3/8" rivets. Holes are a bit bigger, I'd say in the neighborhood of .390 to .400. I drill them to 7/16" Not sure what yours has in it, but I would think 1/2 wouldn't be out of the question. In order to keep things tight in the holes, if they are 1/2" you will probably have to go to 5/8" bolts. I use grade 8 flangebolts whenever possible. Try flangebolts.com
93 K2500 xcab 6.5TD
Old 08-13-2015, 10:54 PM   #7
junkmandan3
junkmandan3's Avatar
Medium duty trucks such as yours usually have frames in the neighborhood of 40,000 psi. OTR heavies are 100,000 psi and higher .
junkmandan3 is offline   Reply With Quote
Old 08-13-2015, 11:56 PM   #8
Jim Timber
So this'll be like working with stubborn mild steel. Should be a breeze!
Thanks guys!
I'm working on my stump grinder the next few days, then I guess I have some cabin repairs to do for the FIL up north from the sounds of things. It looks like the truck is getting delayed a bit.
Old 08-18-2015, 12:00 AM   #9
Jim Timber
I didn't do much with the truck this weekend after all. I put the new plate on the front, noticed the gas tank is empty (not entirely a bad thing), and measured out the 118" for the frame bob.
The cut mark is just aft of the front spring hanger.
So something came to mind when that point was found - the rear of the frame rail is narrower from top to bottom than the belly of the frame. So if I just move the rear hanger's forward, the axle will change it's angle relative to the ground and the pinion will point "up" more. Is this a bad or good thing?
I'm used to dealing with lift kits, although it's been a good 15 years since I modified a suspension. We always had to make the pinion poke up more to straighten out the driveline, but I do remember that being aimed up too much was not desirable.
Will I need to wedge this to correct the angle, or should I just see how things work out when I get it skooched forward? The other thought is that I'm not going to be running this thing more than an oil change a year, so it might be moot.
Old 08-18-2015, 12:35 AM   #10
mrolds88
That depends. Do your front hangers attach directly to the side of the frame or do they wrap under? If they wrap, then yes you'll have to wedge your axle. It would also raise the back of the truck.
93 K2500 xcab 6.5TD
Old 08-18-2015, 12:41 AM   #11
Jim Timber
The front's are going to be on the same plane as they've always been. It's the rears that might end up lower, which would raise the rear end.
This has 24,000# springs in it (27,5 GVWR), so I was thinking about removing a leaf or two anyway just so it rides a bit better.
Old 08-25-2015, 01:26 PM   #12
1976gmc20
Most people just cut the frame behind the cab and add/remove a section to change the wheelbase, rather than messing with spring mounts.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 08-25-2015, 01:56 PM   #13
Jim Timber
I'd rather mess with spring mounts than weld the middle of the frame.
Old 08-25-2015, 05:03 PM   #14
1976gmc20
Okay ... I'm just telling you what truckers that I have known and worked for have done in the past.
What's good for a Peterbilt ought to be good for a Chevy
Old 08-25-2015, 06:42 PM   #15
Jim Timber
I was taught to never weld on a frame by a bunch of diesel mechanics, however that's not the issue at play here (Chevy's upfitters best practices gives numerous methods to do it correctly). This truck is 110 miles from my shop, and I have no flat surface to work on it up there, nor do I have an existing 240v outlet (I could install one if I chose to). But getting the frame cut and welded back together straight given the working conditions is the main concern.
I can rent a mag drill and put the hangers back in perfect alignment in a day.
Old 10-17-2015, 04:18 AM   #16
Jim Timber
After doing some geometry, I'd lose a lot of spring travel if I moved the spring hangers forward and lost the narrow frame tails. So I'm going to cut the middle out of the frame after all.
There's an internally braced section on the left frame rail where they put a 1.5" hole too close to the bottom flange (likely to do with the water pump, as this was a tanker). The repair/compensation looks to have been done well, but I'm going to remove that part of the frame when I shorten it.
I won't have more than a 120v mig welder available, so I'm thinking of just making some bolt on connector plates inside the C and adding part of the removed frame rails to the outside which will get me to where I can drive it the 110 miles to my home shop and weld it with the big mig per the GM best practices. The frame is 5/16" thick - well beyond the capabilities of my little flux core toy.
Which leads me to the question of how long should my bracing be over the splice? GM states no less than 6" either side of cut, but what's ideal? The piece of angle that's added now is probably 18" or better. The dump body sub-frame has connections at 16" behind the cab and forward, and again at 32" rearward. I'm hoping I can tuck my splice in between those, but if I can't it's not a big deal.
I know I mentioned not having a flat place to work on this up North earlier, but I'll be able to move it 1/2 mile up to my FIL's storage place to use the concrete pad there as soon as his pontoon is put away for the season. I'm hoping that's soon. It was supposed to be done last week.
Any input/advice appreciated.
Old 10-17-2015, 04:54 AM   #17
Jim Timber
According to this, I should make them as long as possible.
http://trailer-bodybuilders.com/dist...s-truck-frames
Old 01-12-2016, 02:32 AM   #18
El Dorado Jim
any new pics on the truck?
El Dorado Jim is offline   Reply With Quote
Old 01-12-2016, 11:51 AM   #19
Jim Timber
Nope, it's still parked where I left it this fall (unless it's been stolen), and currently -8F outside.
I do have one that's got a little different angle, but it's not a pic of the Chevy alone.
Old 01-12-2016, 11:54 AM   #20
Jim Timber
I did get another cross member with the hanger bearing mount, so I can get the driveline back together and drive it down to my house for the shortening, but that'll happen when it warms up this spring and the snow is gone.
We're in hibernation mode for the next couple months.
Old 01-12-2016, 11:56 AM   #21
Jim Timber
I forgot about this one too. This was when I first agreed to buy it.
Old 01-15-2016, 12:27 AM   #22
El Dorado Jim
thanks for the pics, I , or should I say my wife has a '74 C65 dump truck, it is an old DOT truck,it has a 5spd, with 2spd rear end, I had the engine rebuilt a few years ago, it has a 427 tall block in it with a holley carb....it has air brakes and a weird air power steering system,seems to work alright, just usually they have normal, power steering I think,what is in your truck? I will post pics, seems to be an interest in these old trucks....
Old 01-15-2016, 01:50 AM   #23
Jim Timber
I'm pretty sure it's just a regular hydraulic drag link set up.
Old 01-15-2016, 06:09 PM   #24
El Dorado Jim
what engine and trans do you have? 2spd. rear end? air brakes?
Old 01-15-2016, 06:39 PM   #25
Jim Timber
5sp, 2sp, and vacuum assisted hydraulic brakes. Pretty normal configuration for the 366.
