Old 08-12-2015, 07:24 PM   #1
68Redhead
Help with White walls
I'm wanting to get me some thin white wall tires and smoothie wheels. I'm thinking 225/75 on 15x7 with baby moons all around. Truck will be lowered 2" in front and 3" rear. My problem is I haven't seen any in person so I need advice on tire and wheel size. Would I be happy with my listed sizes or should I go with 235s? 15x6? From pictures on here I think 215s would be too small for my taste.
68Redhead is offline   Reply With Quote
Old 08-13-2015, 09:48 AM   #2
68Redhead
Re: Help with White walls
Not the best pic but it's all I got. Any insight is much appreciated.
Old 08-13-2015, 10:19 AM   #3
You don't get a lot of selection in sizes with 15" whitewalls anymore. 235/75s are most common. You could pay the price and have Diamondback Classic Tire ( www.dbtires.com ) make any size tire you like into a whitewall any width you like
Old 08-13-2015, 10:43 AM   #4
68Redhead
I found some Hankook Optimos for under $400. I looked at diamondbacks but I'd prefer to not pay around $250 per tire. Do you think 225s would look ok on a 7" wheel?
Old 08-13-2015, 05:27 PM   #5
midniteblues
midniteblues's Avatar
check summit and there mastercraft brand mine are 235/75's on wheel vintiques 15x8 all around.oh and a ece 4/6 drop with 1 1/4 blocks out back
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 08-13-2015, 07:58 PM   #6
68Redhead
Are those 6 lug, midniteblues? A while back I don't think I could find 6 lugs that would fit our stock hubcaps.
Old 08-14-2015, 04:04 PM   #7
midniteblues
5 lug i put disc brakes on the front and already had the 71 5 lug rear axle.
6 lug was oe and these caps woulda come on 6 lug wheels.
any "nub" style hub cap should fit either 5 or 6 lug wheels unless you have the clip style wheels.
Old 08-14-2015, 07:43 PM   #8
Newtz67
Newtz67's Avatar
I just bought a set of the Hankook Optimo h724 235/75/15 last weekend for $370. It's only been a week but I drive this thing 120 mi a day and I really like these tires. The ride is great, they are quiet and I like like how they look. If you want any closer or better pics let me know and I'll get them for you. I'm planning to lower about 4/6 but still staying with this size.
Newtz67 is offline   Reply With Quote
Old 08-14-2015, 08:16 PM   #9
68Redhead
What width are your wheels? The 235s don't look wide on them in that picture. That's quite a commute, I'm too spoiled with AC to drive either of my old vehicles daily!
Old 08-14-2015, 08:44 PM   #10
68Redhead
Just a heads up for anyone else, I emailed dbtires and they recommended their M5 tire at $199 per.
Old 08-15-2015, 07:33 AM   #11
I'm just waiting till truck is almost done to order from Diamondback.
Old 08-15-2015, 09:56 AM   #12
stevencvn72
Kill Bill...et
stevencvn72's Avatar
I went with a 15x7. Offset makes all the difference if you ask me. These are 215/70/15. Small, yes but I wanted to retain my inner fenders. The biggest thing is they're Firestone. The name on the sidewall adds a bit of nostalgia. I couldn't afford the Cokers or BFG Silvertowns although I think those are the best looking white walls. Anywhoo, here's a visual on these. Good luck with your decision white walls are a good choice!
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 08-15-2015, 10:04 AM   #13
CG
BlahBlahBlah
Not positive, but pretty sure, you can get whatever size tire and stripes you want from Diamond Back. The tires in my av are Diamond Back.
Old 08-15-2015, 01:39 PM   #14
Newtz67
Newtz67's Avatar
My wheels are 15x7.
Old 08-15-2015, 10:35 PM   #15
motorcritter
motorcritter's Avatar
Hankooks are the best deal in whitewall tires, they hold up well and ride good, and perform in adverse weather better than I expected. I run them on my old Benz diesel, and the Cheyenne has some on it, with the whitewalls turned inside. I've seen the really nice stuff from Coker's and others like Diamondback. If I was building a show vehicle or a concours restoration, I'd spring for the high-priced skins, but for a daily driver or just a 'nice truck', the Hankooks work well. I avoid the Kuhmo brand- they make whitewalls, but the tires suck. Cooper makes whitewalls in their cheap line (often branded for different vendors), they suck, too.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 08-19-2015, 03:48 PM   #16
UNEASYRIDER
UNEASYRIDER's Avatar
Smile Re: Help with White walls
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline   Reply With Quote
Old 08-20-2015, 03:16 AM   #17
68Redhead
How wide is the white stripe on the Hankooks? Thanks for the input everyone!
Uneasyrider, how wide is the stripe on yours and what size and brand?
Old 08-20-2015, 03:58 AM   #18
franken
Can't help. I think any and all whitewalls are horrible.
franken is offline   Reply With Quote
Old 08-20-2015, 04:06 AM   #19
68Redhead
I was the same way when I joined this site, the thin stripe and hubcap look has really grown on me this year. They have their place, I don't like how the thick stripes look on 67-72's but love them on prior years and rat rods.
Old 08-20-2015, 08:33 AM   #20
I'm sorry, but I just can't come to putting Hankooks on a classic GM Truck. No thanks, I'll spend more to not have an import name
Old 08-20-2015, 11:22 AM   #21
UNEASYRIDER
Originally Posted by 68redhead View Post
how wide is the white stripe on the hankooks? Thanks for the input everyone!
1 1/2 suretrac 225/75/15
Old 08-20-2015, 01:25 PM   #22
motorcritter
Firestone used to make a decent whitewall, in their cheap-azz line. They discontinued them about 3 years back. Cooper used to build tires in the states, as did Kelly-Springfield. I don't think compromising actual tire quality (w/ Coopers) overwhelms my preference for good performance and longevity.
Old 12-20-2015, 08:28 PM   #23
68Redhead
Ttt
Old 12-20-2015, 09:23 PM   #24
davischevy
davischevy's Avatar
235/75/15's on 7" wheels.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
