08-12-2015, 07:57 PM | #1 |
Disc brakes with stock 15" wheels
Anyone know of a kit that will work with a set of stock 15" wheels? Looking for front kits specifically, not going to get into the rears for now.
I like the look of the wheels now, I would just like to be able to stop. FYI, '69 c-10, stock 6 lug wheels. |
08-21-2015, 12:31 PM | #2 |
Happy to be here
Re: Disc brakes with stock 15" wheels
There are aftermarket kits that allow you to convert to 6 lug disc. Check with the Forum Vendors in the Marketplace for more info.
08-21-2015, 01:16 PM | #3 |
67-72 parts collector,…
Even with the aftermarket 6- lug disc brake kits,... You won't be able to use your stock front 6-lug wheels. They don't have enough clearance for the the disc brake caliper. There is a ton on info on this sight about this very subject.
You will need a 71-87 4x4 wheel to clear the caliper. Not a big deal, you just have to find these 4-nub oem wheels. Look at ECE for disc conversion parts. www.earlyclassic.com
08-21-2015, 01:17 PM | #4 |
Look at this thread,...
http://67-72chevytrucks.com/vboard/s...d.php?t=560599
10-02-2015, 07:45 PM | #5 | |
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
10-02-2015, 08:09 PM | #6 | |
I have 15x7's with a 4" backspace on my red '69. But I trim the lower a-arm at the balljoint. 3.75" BS should not be an issue.
10-02-2015, 08:27 PM | #7 |
Thanks Keith!
10-07-2015, 09:12 PM | #8 |
They (wheel vintiques 15x6) don't fit with my new disc brakes. Back to the drawing board. At least I checked before I painted them.
10-07-2015, 11:13 PM | #9 | |
Caliper? Lower a-arm?
10-09-2015, 06:34 AM | #10 |
Caliper doesn't fit in the wheel. I just loose fit it on the floor so no idea about the rest of the geometry yet. Might do some more measuring this weekend and see if I can get by with a spacer for just a bit to buy me some time before I pick out some larger wheels.
10-09-2015, 11:23 AM | #11 |
A lot of the aftermarket calipers have excess casting on them that can easily be ground off if there is a rub somewhere.
I've never had issues with Wheel Vintiques wheels.
10-09-2015, 08:12 PM | #12 |
Captain fab makes parts for a 15" rim and everything fits well. He's on this site
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) MAI Interior shop |
10-09-2015, 09:27 PM | #13 |
I am not grinding my brand new wilwood calipers!
10-09-2015, 10:05 PM | #14 |
Wilwood D52's would be the exception to the poor castings of chinese aftermarket calipers that I was talking about,...
10-10-2015, 09:38 AM | #15 |
I will mess around with it today and see if a spacer might give me enough clearance for now. I am going to go bigger wheels later so it might be a reasonable solution to what will be a temporary problem.
