250 to 283 engine swap advice needed!!
Hi all, I am currently swapping my 250 for a 283 sbc. I found some engine mounts but I was wondering if anything goes in-between the back of the mount and the truck's mount? Also, I heard that I have to move the truck mounts in a certain direction since the I6 was offset? Rhank you so much guys! -Sam
Re: 250 to 283 engine swap advice needed!!
why start a new thread? they go exactly the same place and way.
ron |
Well, I wasn't sure as to how it went in, as I was told that they inline's and V8 mounts were different on the trucks end, having read that I wanted to see how true it was so I wouldn't go and put in a $1200 engine that I worked all summer long to buy and then just have it damaged on incorrectly installed. Thanks for the advice! -Sam
![]() Join Date: Jul 2000
Well, maybe because this is truck forum where people ask for advice.
![]() To the OP: What year is your truck, and do you plan to keep the current trans (what is it?) or switch to something else?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Hi Mike , its a 1966 Chevy C-10 and I am putting a M10 4 speed behind it. Thank you in advance for the advice!!
#6 | |
![]() Quote:
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
#7 | |
he has another thread on the motor mounts currently running and it has all that info on it ron |
My mistake for not doing a search on all his threads before responding to this one. Or yours, for that matter.
#9 | |
The bellhousing will be in exactly the same place. Muncie trans is same overall length as Saginaw 3-speed (not including OD). Depending on Muncie type, input and output shaft O.D. and spline count may be the same as a 3-speed. I'm just now completing a 250 six-to-350 swap in my 82 C10, and the main issues were: 1) Finding the right motor mount "clam shells" (which a 66 doesn't use) and making sure the existing frame brackets I mentioned above would work. In my case, I didn't have to replace or move the frame brackets. But I did have to bolt the cushions (different type than 66) using different holes already drilled on the frame brackets. 2) On the engine wiring harness I had to lengthen some wires, shorten others, and change some terminals, but I could have bought a new V-8 harness from AAW.
#10 | |
ron |
#11 | |
ron |
#12 | |
#13 | |
it is not "any" year chev by the way. it was a little different putting a sbc in my 32 chev sedan a little over 50 years ago. ron i |
#14 | |
Go work on your truck and have some fun!
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 09-24-2015 at 09:17 PM. |
#15 |
I wonder if Samtheman has any more questions on that swap?
#16 | |
Post Whore
![]() Join Date: Mar 2013
[quote=MikeB;7288957]
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#17 |
#18 | |
[quote=TJ's Chevy;7289104]
And heck, why criticize my comments about my 250 six to 350 swap? I know the OP has a 66 truck, and I can do the math to determine mine's 16 years newer. But the issues are similar, even if the motor mounts and other related parts are different. And what's with him lecturing me about a 32 Chevy sedan being different than my 82 C10? Geez, no kidding? I've been working on Chevys for 51 years, but that's a new one on me! Whew!
#19 | |
[quote=MikeB;7319374]
#20 |
Never Ending Projects
Everyone play nice. Only warning....
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#21 |
Sam, I like 283's. I got a stocker, and a warmed one too. I realize my reply doesn't answer your question, but I am curious about what made you choose a 283 and which direction you took with building it. I doubt you'll have much trouble making the swap. Years ago I helped a pal do it the other way, swapping a worn out 283 for a 250 and although I forget the specifics, it was a simple weekend job.
