Old 08-12-2015, 11:13 PM   #1
augiep9
augiep9's Avatar
Turn signal troubleshoot
I am hoping somebody has had this problem because I am just about at a lose. Here's what I have going on. Just got my 68 Chevy back together after paint. I have turn signals and brake lights when headlight switch is off. Turn the headlight switch on and lows, highs, tails, and brakes work just fine but when I turn the switch on the dash turn signal indicators come and and don't shut off. The turn signal lights on the front and back don't come on at all. All of my grounds r good. All new bulbs all around. I also put a new headlight switch on and it does the same thing. Any help would be appreciated.
augiep9 is offline   Reply With Quote
Old 08-13-2015, 02:35 AM   #2
kingstrider
kingstrider's Avatar
Re: Turn signal troubleshoot
I'm dealing with my own electrical issues at the moment so am no help. You have a really nice looking truck though, love that blue paint.
kingstrider is offline   Reply With Quote
Old 08-13-2015, 12:42 PM   #3
augiep9
augiep9's Avatar
Thanks. I'm glad the painting is finally over with
Old 08-13-2015, 12:56 PM   #4
cdowns
cdowns's Avatar
learning how a ground system works is the most important part of getting the lights to work// track the grounds from each and every light bulb to get it done
Old 08-13-2015, 01:02 PM   #5
augiep9
augiep9's Avatar
I have the grounds from the headlights to the core support good. Battery to engine block, engine block to frame, frame to core support, frame to cab, and frame to bed. Which other grounds r there to hook up?
Old 08-13-2015, 01:10 PM   #6
motorcritter
motorcritter's Avatar
Ground each lamp position. My on-hands experience with sensitive systems in modern Japanese and German vehicles taught me that most system electrical faults were traceable to bad or inconsistent grounds. Component failures happen, and are easy to test for- blown bulbs, bad flasher, broken/bare wires- if the grounds aren't there, it's hard to check them out. It's tedious, but, it's worth it overall.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 08-13-2015, 01:31 PM   #7
cdowns
cdowns's Avatar
trace your ground from the right rear taillight to the battery then the left rear taillight to the battery then the right front to battery then left front to battery // trace from each and evry light bulb ground to battery is a requirement to light not just a few straps put randomly around the truck
Old 08-13-2015, 01:43 PM   #8
augiep9
augiep9's Avatar
Makes sense. I will do just that. Thanks
