08-14-2015, 04:14 PM | #1 |
Emergency Brake Lever - Parts
Anyone know if there is a source for new parts for the Brake Levers and Pins on a 72 2 wheel drive rear brakes?
08-14-2015, 05:48 PM | #2 |
Re: Emergency Brake Lever - Parts
I'm not sure what you mean by "lever". The pedal is a lever and I haven't seen anything in parts catalogs listed.
The best place for a parking brake pedal , IMO, would be a junk yard. Classicsparts.com) sells bushings, return springs,rod retainer(clip). Plus if needed they will send you a paper copy to browse (my personal choice) |
08-14-2015, 07:15 PM | #3 |
The Brake Levers are the levers that the Emergency Brake Cable attaches to on the back side of the trailing brake shoe in the rear brakes.
08-15-2015, 09:46 AM | #4 |
Have you tried rock auto, just got a bunch of drum brake parts from them
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-27-2017, 06:24 PM | #5 |
Hi all I've been searching and I can't seem to find the parking brake actuating lever anywhere. It's the very right part in the attached picture. Thanks guys.
12-28-2017, 07:49 AM | #6 |
Rockauto.com has a whole bunch of options for "Drum Brake Self Adjuster Repair Kits".
That's where I got mine...... |
12-28-2017, 10:16 AM | #7 |
Yeah I've got the self adjuster repair kit and the hold downs as well as the spring kit. Im looking for the arm that hold the end of the parking brake cable in the drum.
