4.8 oil pump keeps going out
Have put 3 in a row in it goes right out anyone ever had this problem
![]() Join Date: Sep 2005
Re: 4.8 oil pump keeps going out
have you thought maybe you have a different problem then the oil pump?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
I'm new to this site so hope I'm doing this right I know something is causing it wondering what 3 different oil pumps in a row on a really low miles truck
Hollister Road Co.
That a very vague description. Not much to go wrong in that pump I suspect that the O-ring is missing or damaged or the pickup tube is cracked or broken
3 different oil pumps from 3 different places each time changed I put new oil put it in it will run for a few hundred miles then lose all oil pressure don't know why
blood type; Retumbo
Is it an actual loss of pressure or just the dash gauge showing a loss? (Bad oil pressure sensor)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
It is an actual loss of pressure 3 different oil pumps all bout from different stores so don't really know what is causing it I've talked to several ppl who don't know either thanks for any hrlp
Have you verified pressure with a mechanical gauge?
Does it knock when it looses oil pressure? How many miles are on it? Is the engine worn out? I have never ever seen an oil pump fail on its own. I have seen debris cause one to fail, but at long as you have a screen in the pick up, that cant really happen. Have you taken apart any of the failed pumps to see what happened to them? |
120,000 miles it's knocks when it goes out and there's no pressure don't know if a bearing is going out or what just seeing if anybody has ever seen the problem
