Old 08-15-2015, 10:45 PM   #1
jomatt20
jomatt20's Avatar
350 v8/3 speed Muncie clutch parts question
Hi guys, like said above I have a 72 gmc with 350/3 speed. My question is on the z-bar for the clutch, I have replaced the frame pivot ball bushings and put new felt washer but on the pivot ball that mounts to the engine block, for that side ther was no bushings or anything. The only thing I did put wa a new felt washer. I'm concerned that I didn't assemble it correctly and wanted yalls input. Thanks guys
jomatt20 is offline   Reply With Quote
Old 08-16-2015, 08:49 AM   #2
midniteblues
midniteblues's Avatar
Re: 350 v8/3 speed Muncie clutch parts question
sounds like you did it right.
as long as you got the 2 bushings and the round clip in the z bar on the frame side you shouldnt have any problems.
make sure you get both them ball studs tight. I've seen them work loose and cause problems.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
