Old 09-09-2003, 09:11 AM   #1
Litdave
Straightening tailgates
Hey guys
Is it possible to straighten a bowed tailgate?
I have found a really good tailgate with virtually no rust and just a couple of small dings for $20, but it is bowed about 1".
I have heard of laying the tailgate down and running over it with a truck but I am not to sure about this.
Any suggestions.
Thanks, Litdave
71 Factory SWB 4x4 Project 383/350/205
69 LWB 2wd CST Daily Driver ZZ4/700r4/3.73
72 SWB Future Hot Rod
Litdave is offline   Reply With Quote
Old 09-09-2003, 09:44 AM   #2
JimKshortstep4x4
Smile
Depending on the bow it is usually possible to straighten a tailgate. I used a 150 ton press, (more force than needed) to straighten my shortstep gate. I cribbed it up so that the force was applied evenly across the bow with the ends supported and it was easy to straighten it. I believe that you can do it with a heavy vehicle, but I have not tried it. I think guys have jumped up and down to straight them, also.
Jim
Old 09-09-2003, 11:11 PM   #3
Benrs86
Benrs86's Avatar
i had the same thing put it on 2 2x4s and jump on it. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 09-09-2003, 11:31 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you screw it up, you're only out 20 bucks, and then you can make it into a cofee table for the basement!
