Old 08-16-2015, 03:46 PM   #1
Guss
RPM at freeway speed?
I have a new crate motor, 6.2L LS3, 4L65E trans. Current rear gear is 3.73. GM recommends 3.42 for this engine/trans combo. With the 3.42 and my tire size, RPM's calculate to 2201 at 70 MPH. My question is this, is 2200 rpm going to be in the right range for optimal fuel mileage. I would assume so from a GM engineering standpoint but was looking for real world scenarios. Thanks
Guss is offline   Reply With Quote
Old 08-16-2015, 05:28 PM   #2
solidaxel
solidaxel's Avatar
Re: RPM at freeway speed?
Sounds like a perfect combination to me!
I would not think you would notice that much difference in MPG , are you thinking that 2000 RPM's is the perfect number?
I am thinking out loud, the difference between 20 and 21 MPG difference.
You could always reduce the tire height by 1/2 inch or so.............. after you burn the first set off!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-16-2015, 05:30 PM   #3
GMC-YA68
GMC-YA68's Avatar
I don't know about fuel mileage because I don't care, but I'd keep those 3.73s all day long...
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 08-16-2015, 07:12 PM   #4
clinebarger
3.42 compared to 3.73 is not much of a ratio change to warrant changing gear sets.
clinebarger is offline   Reply With Quote
Old 08-16-2015, 07:57 PM   #5
Guss
I get what you are saying. The 3.73 gear has to go anyway. it isn't a posi rearend and I like to burn the tread off my tires evenly!
Old 08-16-2015, 08:46 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Which rear end are you running? If your using something like a 10 bolt, 12 bolt, or aftermarket GM case, your not going to find 3:42 gearsets anywhere nearly as often as finding a 3:73. Usually then next "common" drop down would be to the 3:23 (again from an availability standpoint) if needing less gear a-la those needing to build load on a boosted motor.
2200 is fine on the highway, and I'd say its right around where most of us sit. Your stall converter and lockup settings will also affect the seen vs calculated rpm. My 4l80e/ 373 12bolt sits about 150-200rpm higher, but the converter has a slipping problem when hot in 3rd.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-16-2015, 09:05 PM   #7
mooseknuckles
mooseknuckles's Avatar
I'm running 3:42 gears with my 6.0l/4l80, and it's right around 2200rpm @70mph....and 2200 is right about when this thing starts to pull... I wouldn't be able to keep tires on it at all with 3:73 gears! if you were doin a lot of freeway driving you could run 3:23 gears easily with that ls3...
mooseknuckles is offline   Reply With Quote
Old 08-16-2015, 11:48 PM   #8
solidaxel
solidaxel's Avatar
Guss, is this truck on the road?
LS 3 4L70E
Old 08-24-2015, 02:07 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: RPM at freeway speed?
6.0 4L80E with 4:10 gears and I'm cruisin at 2400RPMs @70MPH, tires are 29" tall. Truck gets about 16-17 MPG.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
