New center console
Well I'm just about finish with my new center console. I had to make it in two pieces so that it would slide under the dash.
![]() The back part that you can't see houses a 10" sub and amp. It also covers the fuel tank in a fashion inspired by the waterfall in the corvette convertables. The original plan was to put a trans temp gauge on the flat part under the AC controls, but I may end up putting a 10 disk changer there instead...haven't decided. |
67-72 Addict!
Very Nice job!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Low & Slow
I like it! That is basicly the route that I will be going, Whenever I get around to it. btw, How much does that b&m shifter run?
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
Ah, I think it was about 150. I got is like 2 years ago. I liked the idea of a floor shifter, and the linkage in the column was old and worn out. You'd pull it back out of park, and it'd basically fall into first.
Post Whore
![]() Join Date: Feb 2000
Looks real good. Cd player would be great in that location.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Really nice! I wondered how that would look!
U.S.A.F. 68' C-10 Stepside 305 w/ 4 speed |
Not Dusti,just Bob
Looks good to me.
72 cheyenne super 1/2ton 89 camaro |
Looks really good! You could put in one of those LCD screens as well.
Zurbo's Chevy - 1972 Black/White Cheyenne Super. 402 Big Block /THD 400, factory air and tilt. My other Chevy - 1998 Camaro SS |
Low & Slow
Thanks for the info!
#10 | |
