![]() Join Date: Feb 2012
rubber floor mat for my 86
I am having the seat recovered and want to put in a rubber floor mat while its out. Who's mat should I get ? lmc, brothers, gmc pauls ???
Post Whore
![]() ![]() Join Date: May 2015
Re: rubber floor mat for my 86
I've had 2 different ones from lmc in mine..the first one fit sorta ok but not great..I had a floor shift and changed trans so I had to get another one..and this one really sucked..fit was awful..
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
That's good to know. I would like the rubber mat but carpet is always a good option. Any info on good fitting carpet??
It followed me home?
stockinteriors.com
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
I never liked the fit of the factory vinyl flooring on my 76, and it had a lot of cracks at the bends, so I went with carpet from a local upholstery shop and covered it with Huskyliners and black exercise mat over the hump and sides of the floor under the seat. You can get a one piece Huskyliner to cover the hump if you don't have a floor shift (if they still make them.)
I would consider the 1/8" thick molded vinyl flooring from LMC or elsewhere. Maybe someone who bought it can post here and let us know how it worked out for them. I think the stock style vinyl flooring is too thin for everyday hard use. Even the 2000 Silverado work truck I bought new had what I considered ill fitting and thin factory vinyl flooring. Huskyliners (or Weather Tech) have the advantage of upturned edges which collect dirt and liquids and keep the carpet clean. |
#7 | |
![]() Join Date: Oct 2014
http://www.brotherstrucks.com/prodin...er=CPT81CC%2DS |
