![]() Join Date: Feb 2012
high hump low hump ??
my 86 was 3 on the tree and I wasn't sure if its a high or low hump. I think its low but need expert advice on that.
Thanks Wes |
Re: high hump low hump ??
Its a low hump.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Robert Olson Transport
![]() Join Date: Oct 2002
yes low bump high humps are bolted on and are only on four wheel drive models ( unless you have a cab change or 2wd conversion on a 2wd )as it has a high hump
Yes its a low hump. The 84 and up high humps are NOT bolt on.
driving is in my blood
Weird, I've been into 73-87's since I was a wee pup and I've never seen this talked about. Whats the point on a high hump? I've fit sm465's, th350's, 200-4R's, muncie M20's and 700R4's in the "small humps" so I don't understand the need?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Low hump is 2wd auto and column shifted manual (M62 and M64 Saginaws).
High hump is everything else: 4wd or floor shifted manuals (SM465 or MY6 New Process - even 2wd). It's driven by the required clearance underneath. The requirements are much more conservative when you are accounting for the variation of building 1.5 million trucks vs building one truck. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-17-2015 at 10:58 PM. |
Stupid question, but why did they even make the variance then? Why not just make it all high jump?
My guess would be if you don't need a high hump for the transmission then you get a little more leg room for the middle passenger.
#9 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#10 | |
The reason I ask is because my 75 donor truck has a much nicer cab than my current 80 cab and Im thinking about swapping them. |
Ahhh I see. In that case my 78 is a high hump [factory 2wd/sm465/8pack leaf springs], and it is welded not bolted in. I've only had the sm465 and M20's in that truck. My 79 must have been small hump and that fit the th350 and 200-4R.
#12 | |
#13 |
Some of my personal hump pictures for your enjoyment. Both doner were 4x4 automatic.
This one was a 74 C10 that I put a 5 speed into (Camaro T5) and required a high hump. This was a bolt in high hump. Simple sheet metal screw installation. ![]() This is the high hump from my latest C10, frame Z 2.5" and 6 speed (camaro T56) that required the high hump. As you can see this one does not have the bolt in option. ![]() ![]()
#14 |
#15 |
Would a high hump be required in a c10 for a 4.8/nv4500 I’m planning on installing?
#16 |
![]() Join Date: Jun 2016
Ditto what wraprail said. I have a TR6060 in my 86. I had to cut the hump out of an 85 donor truck to put in mine.
And sorry, I dont know the answer to your question IR2, if you need a high hump for your trans. Bubba |
#17 |
![]() Join Date: Jun 2017
made this a while back.
1949 Chevy 3100 P/U http://67-72chevytrucks.com/vboard/s...d.php?t=302780 1976 GMC Sierra Classic C35 CCSB http://67-72chevytrucks.com/vboard/s...25#post8188825 |
#18 |
![]() Join Date: May 2010
It only has original paint once |
#19 |
i currently have a th400/np203 range box to offroad design doubler plate to np205 all under a stock 1987 c/r-10 2wd low hump floor sitting on a k30 frame with energy suspension body mounts and NO body lift .
the 3 shifter lever mounting bolt is dimpling the floor so i know where to open it up for the 3 shifter levers .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#20 |
![]() Join Date: Jun 2009
Ray is spot on!
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
#21 | |
![]() Join Date: Feb 2004
