Old 08-17-2015, 01:31 PM   #1
blown240
blown240's Avatar
Rear Drums Dragging in Reverse?
On Friday I was driving in near 100 degree heat for about 30 mins in stop and go traffic. When I got to where I was going, I had to back into a parking spot and the brakes were dragging pretty bad. I know if the rears because the e-brake handle had lots of slack. It seemed to only be dragging in reverse.
Are my rear brakes too tight? Or is this one of those things that happens when its really hot out?
My poor truck got up to about 220 degrees, oil pressure was down, and it didn't really want to charge. Is summer over yet?
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 08-17-2015, 02:05 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Rear Drums Dragging in Reverse?
I'd suggest pulling the rear drums and take a look at the adjustment. See if there are self-adjusters in there that aren't set up properly.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-17-2015, 02:33 PM   #3
blown240
blown240's Avatar
nothing looks odd under the drum from what I can see. I just replaced all the hardware, shoes, wheel cylinder, soft lines, etc about 3 weeks ago. I am pretty sure that it doesn't have self adjusters. Its a 61.
I drove the truck now and it seems fine. It rolls normally at an idle, and backs up ok. Its also, MUCH cooler out right now.
Old 08-19-2015, 04:50 AM   #4
luvbowties
luvbowties's Avatar
Smile Re: Rear Drums Dragging in Reverse?
Also check to see if shorter and longer shoes are in their correct respective places--the shorter one goes to the front.
Sam
luvbowties is offline   Reply With Quote
Old 08-19-2015, 12:32 PM   #5
blown240
blown240's Avatar
Ill have to check that. Not sure which one is in front...
Old 11-13-2015, 04:57 PM   #6
blown240
blown240's Avatar
A little update on this. Finally was able to get to a flat spot to work and pulled the drums. I have all the big shoes on the front wheels, and the small shoes on the back. Looks like Monday ill be moving shoes around....
Old 11-13-2015, 05:36 PM   #7
Wrenchbender Ret
Check to make sure the emergency brake cables are not too tight or sticking. If the shoes are not returning to the anchors it can cause a drag.
Wrenchbender Ret is offline   Reply With Quote
Old 11-13-2015, 09:05 PM   #8
luvbowties
luvbowties's Avatar
Hey, my response in #4 meant that EACH WHEEL uses a short lining on its front and a longer lining on its rear. Glad you found your misplacement of the linings: now you are on the right track. Enjoy the outcome of your upcoming job well done.
Sam
Old 11-13-2015, 09:16 PM   #9
luvbowties
luvbowties's Avatar
You said, " the brakes were dragging pretty bad. I know if the rears because the e-brake handle had lots of slack." Usually, if all else is correct, lots of slack in the e-brake handle would indicate rear brakes adjusted TOO LOOSELY.
Sam
Old 11-13-2015, 10:18 PM   #10
blown240
blown240's Avatar
Cool. Thanks Sam!
Old 11-15-2015, 06:19 PM   #11
PGSigns
PGSigns's Avatar
I had the pic that shows the front. Should help folks see how they go together.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
