08-17-2015, 02:53 PM | #1 |
Trying to fit 1979 van steering column in 66 c10
First question post as I am kinda dumb founded have some ideas but wanting to make it safe and reliable.
Below is a picture of the 2 steering columns. The one on left is the one out of a 1979 van. The one on the right is the one that came with the truck. Father-in-law said it was out of a camaro. Notice the large length difference. I dry fitted the van column and yeah like 18" too short (story of my life). How could I get this to safely work in the truck? |
08-17-2015, 03:05 PM | #2 |
Re: Trying to fit 1979 van steering column in 66 c10
It's kind of hard to tell, but is the van column splined where the rag joint would go? If so you need to remove that and get a u joint and add a lower steering column from a truck to it. look here at post #35 page 2 http://www.67-72chevytrucks.com/vboa...=259536&page=2 , It is also hard to tell but that doesn't look like a 79 van column.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
08-17-2015, 03:09 PM | #3 |
There is no spline on the end of the van. It is direct to the rag. So I was thinking removing that and then adding the u joint to the end of that and then attach the one from the camaro to the end of that.
08-17-2015, 08:34 PM | #4 |
This is just an idea. I had a tilt column put in my 65 Suburban in 1999. It came out of a 72 Chevy pickup. The only mods were to the shifter rod that goes to the trans but its great. Right length too.
08-17-2015, 09:01 PM | #5 |
My father-in-law doesn't want to have a column with a ignition switch in it is why. Plus we have the van column.
08-17-2015, 09:13 PM | #6 |
That will work. I just cut my shaft and added a u joint to lengthen mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
08-20-2015, 01:12 PM | #7 |
08-20-2015, 01:28 PM | #8 |
I guess Monday I will go to the pick n save and see if they have a nice one there. Cheers 65chevysub
08-20-2015, 01:58 PM | #9 |
That van column looks like an 80's column. The van column up to 79 will look like your original. Round and smooth.
08-24-2015, 05:20 PM | #10 |
08-24-2015, 05:32 PM | #11 |
Many thanks will probably go have a look see tomorrow. If not I will just u joint it and weld it to it. Many thanks all for the advice and information
08-25-2015, 04:36 AM | #12 |
