08-17-2015, 09:17 PM | #1 |
post pics of your rack and pinion installed
Having issues trying to get my dodge Dakota rack to work. Would like to see how some of you guys have yours done.... Thanks
08-18-2015, 06:10 PM | #2 |
meowMEOWmeowMEOW
Re: post pics of your rack and pinion installed
There aren't a ton of rack swaps, as I've queried this myself a while back. You might have some luck in the suspension section if you don't get much here.
I'll be adding RnP to mine, but using a late model 1500 rack with a flipped case. What issues are you running into?
08-18-2015, 08:26 PM | #3 |
I have Porterbuilt if interested. Have extra tie rods as well.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-19-2015, 02:16 PM | #4 |
Not a bolt in but u can check out my build thread.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
