09-09-2003, 11:22 AM | #1 |
67 Grill Ideas
Ok the grill on my 67 is probably going to be one of my next projects. However I do not want to go with the factory look. I want to keep the outer shell but want to do something to fill in the open space. I really like the way the billet grills look but I can't find one for a 67. Does anyone have any ideas or seen something that looks really trick. Post pics if you have them please. Thanks in advance.
1969 Chevrolet SWB Stepside 1959 Chevrolet apache * Sold 1967 Prostreet Chevy SWB Fleetside *Sold 2014 1/2 ton Crew Cab Chevrolet 4x4 |
09-09-2003, 11:58 AM | #2 |
Mike
You need to make one.Get a grill for a 71-72 a cut it to fit.The bend is very close to the same as a 67-68
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
09-09-2003, 11:59 AM | #3 |
thanks I appreciate the help.
09-09-2003, 12:00 PM | #4 |
Resident Curmudgeon
I think there was a 67/68 phantom grille used on one of those high-buck trailer queens but it still fell short of the original IMO. I think that's why you don't see them as an aftermarket item as it looks out of place on the 67/68. On a 71/72 grille it looks okay, maybe you should switch to that style?
But if you're hell-bent on destroying one of the finest looking grilles ever made (next to the GMC of course) you may want to go all out and graft one of these babies in. It'll achieve the uniqueness to which you aspire.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
09-09-2003, 12:16 PM | #5 | |
09-09-2003, 12:47 PM | #6 | |
Resident Curmudgeon
FYI, I was just having a little fun with ya. But the Edsel grille WILL make it stand out. You may want to find a 67/68 grille that has a damaged center bar since you'll be cutting it out. That way you'll have your original (assuming undamaged) to go back to or sell it for some $$. Just a thought.
09-09-2003, 01:21 PM | #7 | |
09-09-2003, 01:23 PM | #8 | |
http://community.webshots.com/s/imag...4YBbnjo_ph.jpg
09-09-2003, 01:24 PM | #9 |
that didn't work, says forbidden.
09-09-2003, 04:43 PM | #10 |
Over worked under paid
grill insert
Roger '69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears Last edited by THOR 50; 09-09-2003 at 05:17 PM. |
09-09-2003, 04:49 PM | #11 | |
Re: grill insert
09-09-2003, 10:14 PM | #12 |
I like the billet grille.
U.S.A.F. 68' C-10 Stepside 305 w/ 4 speed |
