headers
What headers are you 4 speed guys running? can you run long tubes or are you stuck with shorty's
Brian |
![]() Join Date: Feb 2007
Re: headers
Hooker long tubes with full 3". Are you running a sb or bb?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Re: headers
I ran chevelle headers on my big block 4wd. Hydro clutch need to moved but no big deal.
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
Re: headers
I always run full-length. You just have to look at the rear tube on the driver side and make sure it goes straight down or slightly forward. The only other possible issue is if they don't drop down enough to clear the lower arm on the bell-crank. I've had to cut that off and move over
Re: headers
I am running a sb you wouldn't happen to have a p# would you
Brian |
Re: headers
I'm running a big block so i guess that doesn't help ya but I'm running these:
http://www.summitracing.com/parts/hok-2463-1hkr
Re: headers
thank you though
Brian |
Re: headers
any one have p# for long tube headers that work good on a sbc with a 4 speed
Brian |
Re: headers
Doug Thorley 364-y
1976 K15 Short/Step 1981 C10 short/wide 1994 K1500 ECSB |
Re: headers
Heddman was the only header I could find that would work with the manual trans linkage when I put them on the Jimmy. I ditched them for 2 1/2" 'vette manifolds and could not be happier. My butt-o-meter shows about equal output on the top end with a little cam (Crane 266, 210 @ .050) and feels like it makes more low end torque. I went from 2 1/2" pipes on the headers to 2 1/2" on the manifolds which helped equalize the ouput I'm sure. Walker DynoMax Hemi Turbo mufflers were my choice. Nice sound with LOTS of sound deadening.
Posted via Mobile Device |
Re: headers
MikeC, did you use the dorman 2 1/2 ram horns? If so how are they holding up?
Thanks |
user # 2756
![]() Join Date: Jun 2001
Re: headers
I have the GM 2.5" ramhorns on my 70 GMC for 10+ years now, running strong.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
#13 |
Re: headers
I don't remember where I ordered them from but they are most likely the same as the Dormans. They've been on the truck 15 years now I bet. I bandsawed the generator mounts off and then painted them with Eastwood cast iron dressing if memory serves.
#14 |
Re: headers
Thanks Jim and Mike, Im considering going with some Dormans but being that they are now made in China Im wondering how they would hold up in a heavy K20 suburban that will be towing a trailer.
#15 |
Re: headers
I would think they would be fine. My manifolds came from Speedway motors if memory serves and they were not listed as Dormans. But most likely all are made in the same Chinese factory.
| Bookmarks |
