HEI Problems
Hello my name is Dennis and i'am new to your wonderful site, I have a 67 CST C-20 that was my fathers truck then my brothers that recently passed away, he was a mechanic and rebuilt the original 327 block has 72k and updated to HEI distributor, have never had one problem with this baby until yesterday it just quit while driving it, like someone shut the key off! in checking with a 12v tester it has constant power at batt wire to dist, but has no power at tach wire while cranking, replaced control module, nothing, could it be either the coil pick/up? or the coil itself in the cap? please any help would be greatly appreciated, it is my only way to work, and had my brother not passé last month it would be running, thank you so much.
#2 | |
![]() Quote:
Next, like you suggested, I'd suspect the pick-up coil. But do the easier 'power on while cranking' check first. Sam |
Re: HEI Problems
me i'd check to see that you have a dedicated 12v source to the hei as plenty of guys just used the original wiring and that burns up the hei because of the resistance wiring in the original wiring
Re: HEI Problems
Might want to go to the Mad Electrical site. He has really good Tech tips and I believe this subject is one of them. You could even give him a call as Mark is really savvy on this subject. Here's a link;
http://www.madelectrical.com/ Tell him one of the guys from the 67-72 Chevy Trucks Forum sent you.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: HEI Problems
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: HEI Problems
There is no power while cranking, and control was replaced, so I will try the pick/up coil, hopefully that's it? could it also be a bad ground? do these HEI distributors just flat out quit with no warning? cause like I said before this truck has never let me down, and I believe it was converted to HEI about 20 years ago. I really appreciate all your help and advice, cause i'am flat stumped. short of buying a whole new HEI distributor. Thanks again ~ Dennis.
#7 | |
Msgt USAF Ret
Re: HEI Problems
Run a wire from the battery positive post to the BAT terminal on the distributor. Crank the engine, If there is no spark then the distributor is faulty. If it sparks then the ignition system (key switch or wiring) is the problem.
Re: HEI Problems
What I mean is using a test light and probing the tach wire on that goes to the distributor while hooked to the positive post on the battery, it should flash everytime for each cylinder I get nothing, so im told its either the pick/up coil or the in cap coil itself.
Re: HEI Problems
Vettevet, I was told that run from negative on the battery to batt terminal on the distributor with key on should should light and be steady, for testing the control module, and positive on battery to the tach wire on the distributor cap and cranking engine should flash test light, and that test is for the control module. Now im confused did I mix up the procedure for those tests?
Re: HEI Problems
[QUOTE=DHighway;7279285]Vettevet, I was told that run from negative on the battery to batt terminal on the distributor with key on should should light and be steady, for testing the control module, and positive on battery to the tach wire on the distributor cap and cranking engine should flash test light, and that test is for the pick/up coil . Now im confused did I mix up the procedure for those tests? did I goof?
Re: HEI Problems
At this point replacing the whole distributor seems better for me, I pave highways not chase down electrical on a old but sweet 67 Chev truck.
#12 | |
Re: HEI Problems
#13 |
Re: HEI Problems
The tach output on the distributor is just that--an output. It means little as a test.
You need to check the 12V input to power the HEI. If the engine cranks, you most likely don't have a ground problem. So assuming 12V in, and no spark, best guess w/o pulling the cap is a bad module. Maybe the coil, but that's rare. Simply ordering and shotgunning parts is a great way to waste money, and not much more. For some reason, people choose the most expensive part that's hardest to replace to swap for no reason. What did you choose? |
#14 | |
Re: HEI Problems
#15 | ||
Msgt USAF Ret
Re: HEI Problems
#16 |
Msgt USAF Ret
Re: HEI Problems
#17 | |
Re: HEI Problems
#18 | |
Re: HEI Problems
#19 |
Re: HEI Problems
dialetric grease is important to cooling the control module. If you skimp on it or dont put any at all on it the module will fail.
I made this very mistake. brand new module failed in less than 3 months. |
#20 | |
Re: HEI Problems
#21 |
![]() Join Date: May 2013
Re: HEI Problems
This is what I would do , if you power the distributor and it does not fire , its a distributor problem, making sure the wire from the selinoid is hooked so that you have power while cranking , if it does fire its a wiring problem , my guess is a wiring problem , as you say there is no power to the distributor . Could be the distributor is hooked to a random fuse , Ive seen that most of the time , check your fuses , the power wire to the distributor does not flash
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#22 |
Re: HEI Problems
Thank you for you advice 67Chevelle, but I fixed it, it was the pick/up coil, and the shaft was worn as were the advance cuve weights, so I bought a performance distributor, and it fired right off.
#23 |
Msgt USAF Ret
Re: HEI Problems
Kudos to you and my sympathies for your brother.
