Old 08-19-2015, 10:52 AM   #1
ndopita
ndopita's Avatar
HELP! Miss on #6
Over the past few weeks, my 1969 C10 has developed a strange miss on cylinder #6. I've replaced plugs, wires, cap, rotor, ignition module, (it has HEI), adjusted the valves, checked for vacuum leaks, and played with the timing, and NOTHING seems to help. It is a very consistent miss, but only misses below ~1400 rpm, after that it runs perfectly. The engine is a TBI 5.7 block bored to 355, vortec heads with beehive springs, comp xe268 flat tappet, with an edelbrock performer rpm and holley vac. secondary 750. Any ideas on what might be causing this would be much appreciated.
ndopita is offline   Reply With Quote
Old 08-19-2015, 11:54 AM   #2
Aruba1
Re: HELP! Miss on #6
Have you checked the compression?
Aruba1 is offline   Reply With Quote
Old 08-19-2015, 01:26 PM   #3
ndopita
ndopita's Avatar
No not yet. I plan on checking that in the next couple days.
Old 08-19-2015, 02:23 PM   #4
Wrenchbender Ret
Weak valve is the first thought but you might check the vacuum outlet on the intake manifold behind the carb. It feeds on #6&8 cyls. A vacuum leak here will cause a miss at low speeds.
Wrenchbender Ret is offline   Reply With Quote
Old 08-22-2015, 11:42 AM   #5
ndopita
ndopita's Avatar
Compression holds at 120 psi. I also replaced the coil and condenser, as well as checked for vacuum leaks and nothing seems to help.
