08-19-2015, 11:03 AM | #1 |
66 327 original parts decode
Can someone help determine if these parts are original and what the numbers on them decode to? They are off my 66 327, TH400, A/C. I'd like to get whatever is original rebuilt so I can get them back on the truck.
Alternator - seems to be original AC Delco Master cylinder and booster - can't find numbers on the booster Blue streak coil - looks kind of newer but not sure Starter - need to clean up still, will there be numbers located on it? Radiator - Harrison, trans cooler busted inside so the shop that boiled it killed the 2 trans lines. U F R letters on top tank B M on bottom tank. Tag looks to say "DRC". |
08-19-2015, 11:25 AM | #2 |
Re: 66 327 original parts decode
08-19-2015, 11:53 AM | #3 |
On the alternator, the GM part # is 1100774 55Amp and 7F6 would be July 7, 1966
The coil I believe is an aftermarket replacement. Should be a Delco coil And the MC and booster look correct for factory applications but let the 66 pros be the answer on those items. The Harrison radiator would be correct manufacturer....should be a GM part # to correspond with that also. Normally on the upper tank it will be embossed in.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-19-2015, 05:19 PM | #4 |
08-20-2015, 12:42 AM | #5 |
60-66 Nut
I don't see a trans cooler in that radiator for your TH400. I believe a radiator for a AC truck should be a 4 row core. I can't tell if yours is or not.
08-20-2015, 02:09 AM | #6 |
As mentioned the shop that boiled the radiator terminated the trans cooler lines because it busted inside and was leaking water into my transmission. And it is a 4 core
08-20-2015, 09:24 AM | #7 |
Starter # shows 65-68 big block hi torque with that one being made June 6, 1966
08-20-2015, 11:09 AM | #8 |
08-20-2015, 01:19 PM | #9 |
In my buddies parts book the part number for 65-69 passenger 396, 409, 427 & 66-69 Chevelle, Camaro, & Nova with 350 & 396 manual trans (1107365 starter is referenced to that nose also).
Online searches show that its actually a pretty rare and desired piece by the corvette and big block car resto guys. Can't verify it was original to the truck, but the date code is close enough that it may have been. Hard to say with 50 years of age to it.
08-20-2015, 06:26 PM | #10 |
The master cylinder does not look original with the bleeder screw there. Likely a service replacement part.
The booster is correct. There are no ID numbers on them. The radiator certainly looks correct. The 1978 GM Truck Parts Books does not list your application (just everything else) so can't match up any of your numbers. |
08-20-2015, 06:58 PM | #11 |
starter 1107365 would be correct for 327
08-20-2015, 06:59 PM | #12 |
do you have the buildsheet?
08-20-2015, 07:37 PM | #13 |
08-20-2015, 09:58 PM | #14 |
what is the vin number c2534???????
08-20-2015, 10:41 PM | #15 |
08-20-2015, 11:11 PM | #16 |
from the vin look to be a fremont truck early to mid june build which fits the starter and alternator is it a custom camper? does it still have the spid sheet on the glovebox door. check behind the seat sometimes the buildsheet is hidden there .
08-20-2015, 11:24 PM | #17 |
08-21-2015, 12:24 AM | #18 |
60-66 Nut
Since it sounds like you are going for a numbers matching complete original restoration, they should have simply replaced the trans cooler in the radiator. Without it, you will have to run an external trans cooler, which definitely is not original equipment. The in radiator trans cooler also helps get the trans fluid up to operating temp quicker than with an external cooler.
08-21-2015, 08:48 AM | #19 | |
08-21-2015, 09:32 PM | #20 |
with the 327 turbo 400 it would be a 4 core
08-21-2015, 09:54 PM | #21 |
Any good radiator shop can install a new 4 core and replace the bad trans heat exchanger in the bottom tank
08-25-2015, 10:24 AM | #22 |
