Old 08-19-2015, 12:01 PM   #1
craigg1
Buying newer truck for donor parts
Im in the process of buying a 68 Chevy c10. Thinking about buying a cheap 2000-2002 chevrolet that has a 5.3 engine. I would like to be able to use the engine, power steering, power brakes, A/C and possibly the transmission from the donor to put into the 68 truck. Does this sound doable? Im far from a mechanic but wanting to see what my options are and how hard it would be to make the newer truck parts fit the old truck. Any suggestions welcome. Thanks.
craigg1 is offline   Reply With Quote
Old 08-19-2015, 12:06 PM   #2
CRMW
Re: Buying newer truck for donor parts
I'm doing this with a 2004 doner and a 1972 C20. The toughest part was finding a 2wd truck, I almost went with a van but a 6.0l 2wd showed up. I'm still working out the details and driving the doner to make sure the drivetrain is in good shape before the transplant.
CRMW is offline   Reply With Quote
Old 08-19-2015, 12:14 PM   #3
craigg1
I was seriously thinking about a 6.0 as well but will probably end up going with a 5.3 since there seems to be more and cheaper donors to choose from. Do you think it will be a fairly easy swap or will there end up being a lot of modifications?
Old 08-19-2015, 12:18 PM   #4
CRMW
From what I've seen the 4.8, 5.3, and 6.0l swaps all seem to be about the same amount of work. The amount of work will probably end up being a lot more than I anticipate but everything is relative.
Old 08-19-2015, 12:24 PM   #5
67 chevelle
67 chevelle's Avatar
look here
http://67-72chevytrucks.com/vboard/f...play.php?f=206
I have done 2 ls swaps one into a 67 the other into a 68 , they are fairly straightforward , others have done your legwork for you , the discussion above from this board will answer most of your questions
In fact this thread http://67-72chevytrucks.com/vboard/s...d.php?t=679407 on that discussion will answer 95% of your questions
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-19-2015, 12:28 PM   #6
craigg1
Great, thanks for the link, that will be a lot of help.
Originally Posted by 67 chevelle View Post
look here
