08-19-2015, 04:40 PM | #1 |
Anybody used CPP's rear disc brake kit?
what did you use for rotors? thanks, Larry
08-20-2015, 10:05 AM | #2 |
Re: Anybody used CPP's rear disc brake kit?
anybody?
08-20-2015, 11:06 AM | #3 |
I ordered the whole kit with rotors, I may be able to pull a part number to see what they are off of.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
08-20-2015, 02:28 PM | #4 |
I used rotors & calipers for a 79 Caddy Eldorado...same 5x5 bolt pattern.
I bought the bolt on brakes from some guy on ebay that sells them. I only ended up using the e-cable from CPP to complete my install. |
08-20-2015, 04:42 PM | #5 |
CPP only gives me their part # for the rotors and won't say what fits. they do tell you what calipers fit
08-20-2015, 05:44 PM | #6 |
I have cpp on one of my truck not happy at all. Everything is new my brakes suck i have work and worked on them still have hard brake they make noise should have saved my money bought Wilwood I even added a electric power booster no diff. Think I am going to dump the power brakes go to wilwood manual.
08-23-2015, 02:29 PM | #7 |
I don't want to buy CPP's rotors and they won't tell what fits their bkt besides their rotors
08-23-2015, 03:29 PM | #8 |
Moderator
Try 79 el dorado rotors. I believe those are the calipers they use in their kit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
08-23-2015, 06:12 PM | #9 |
Old member
This thread has my install pictures + some others to.
Mine work but no big inprovement over the drums at all that I can tell. http://67-72chevytrucks.com/vboard/s...=572063&page=2
08-24-2015, 10:06 AM | #10 |
thanks for the info Andy. if you had to replace your rotors, do you know what they came off of, or would you have to buy CPP's? thanks, Larry
08-24-2015, 12:47 PM | #11 |
You can be sure they aren't anything custom made for them. They came from some stock application. They just won't tell you what. If they did people like me would go straight to the junkyard to get brake calipers, the parts store to get rotors and pads, and cut them right out of the deal.
Which I am pretty much doing anyways. |
08-24-2015, 12:56 PM | #12 |
08-24-2015, 01:51 PM | #13 |
Old member
Nope have no idea. Never thought about it. The brake pads are normal pads that you can buy at the parts store.
08-24-2015, 03:42 PM | #14 |
I've had nothing but issues with everything CPP I've ever purchased with the exception of a rag joint. Go talk to Travis at Pro Performance (vendor here) he'll hook you up with a Wilwood set up that works. I just posted photos on my build thread today, if you want to take a look. HAPPY!
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
08-24-2015, 04:12 PM | #15 |
Moderator
08-24-2015, 07:18 PM | #16 |
08-24-2015, 07:31 PM | #17 |
08-25-2015, 11:14 AM | #18 |
08-25-2015, 02:40 PM | #19 |
Then ask autozone or walmart or whatever for rear rotors for 78-79 cadillac seville, $42,99! When you go for pads or calipers, same car 'cause that's what CPP uses.
08-25-2015, 02:43 PM | #20 |
Moderator
08-25-2015, 02:44 PM | #21 |
Moderator
Ding! Ding! Ding!
08-25-2015, 03:57 PM | #22 | |
that's not true. do you have the kit? did you do the swap? as far as pads, wrong again. the kit uses Mailbu calipers |
08-25-2015, 04:23 PM | #23 | |
So to answer your questions: 1. I have the CPP kit. 2. It is installed on my 67 Chevy stepside 3. I have purchased pads for it at O'reilly Auto Parts. 4.I used the part numbers for the 1979 Cadillac Seville 5. They fit and now have 15,000 miles on them Go try to bolt Malibu calipers on those brackets. If you try enough of them you just might stumble across a pair that are interchangeable with those on the Seville. Good Luck! |
08-25-2015, 08:15 PM | #24 |
Agree with LEDDZEPP and TAIBO. The kit I used from Toms Classic-eBay ...uses the 78-79 Seville calipers/rotors.
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
08-25-2015, 09:25 PM | #25 | |
Chevrolet Nova (1968–1979) Buick Apollo (1973–1974; 1975 sedan only) Buick Skylark (1975 coupe only; 1976–1979) Oldsmobile Omega (1973–1979) Pontiac Ventura (1971–1977) Pontiac Phoenix (1977–1979) |
