08-19-2015, 06:51 PM | #1 |
what size wheels can I use
I have a 76 gmc 1500 that has a 4" drop in the front and 5" in the rear. My question is what is the biggest wheel I can use? It currently has 15's on it now and it doesnot look like I have a ton of room left. I don't really want to cut the wheel wells.
08-19-2015, 07:50 PM | #2 |
67-72 parts collector,…
Re: what size wheels can I use
You can easily run a 8"-8.5" wide wheel up front and a 10" wide wheel in the back.
(unless you are talking tire diameter) Hard to tell what you meant.
08-19-2015, 08:13 PM | #3 |
Diameter
08-19-2015, 08:14 PM | #4 |
Diggin The SquareLife
you can do 22" but would have to use a thin tire....but you can do 20" with a good tire no problem
08-19-2015, 08:22 PM | #5 |
27" up front and 29" on the rear would be a good combo.
I don't know what diameter WHEELS you are talking about,... but in 20's a 245/40 or 255/40 on the front and a 275/40 or 295/40 on the back.
