Old 08-20-2015, 12:13 PM   #1
The1960APE
The1960APE's Avatar
Wheel Fitment
Hi guys,
Being very unfamiliar with these trucks I have what I assume is a elementary question. I have a 60/61, I am going to run drop spindles and turn the bars down in the front, in the rear I am either going to run a 4" drop spring or a 2" drop spring and 2" blocks (for increased ride quality)
After lowering the truck Wheels will be a must, I was looking at some of the US Wheel Rally style wheels, would I have issues running 16x10 in the rear and 16x8 in the front with a decent size tire (no super low profile tires) I am leaning towards a white wall with a decent height sidewall.
Does anyone have pictures of a similar setup?
In addition, what vendor do you guys suggest for the springs, drop spindles and blocks?
Thanks so much!
The1960APE is offline   Reply With Quote
Old 08-20-2015, 12:38 PM   #2
verdell
verdell's Avatar
Re: Wheel Fitment
The front shouldn't be a problem. Is your truck stepside or fleetside? The 10 inch wide rears might be pushing it depending on the backspacing but I'm sure other members can verify. Also, I think a good 4" drop coil may provide the same ride quality as 2" drop plus blocks. What about it, Guys?
verdell is offline   Reply With Quote
Old 08-20-2015, 12:40 PM   #3
The1960APE
The1960APE's Avatar
Re: Wheel Fitment
It is a step side!
Old 08-21-2015, 04:45 PM   #4
forestb
forestb's Avatar
Re: Wheel Fitment
I have 8in wide wheels on the rear of my step side with standard back spacing and 275 wide tire. When I had a 4 inch drop I had no clearance problems. I don't know how much a wider wheel increases the width of a wide tire. If you are sure you are going to stick with a 4 inch drop I would get blocks and springs. I have always heard that keeping the springs to as close to stock as possible is best. It also allows you to have shocks with more travel.
forestb is offline   Reply With Quote
Old 08-21-2015, 09:19 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Wheel Fitment
http://www.67-72chevytrucks.com/vboa...d.php?t=379110 Check out this thread if you haven't already. Maybe you can find your size.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-14-2015, 11:39 AM   #6
The1960APE
The1960APE's Avatar
Re: Wheel Fitment
All of my suspension, brakes etc are ordered, I ended up converting to 5 on 5, 3" rear drop springs 2" rear lowering blocks, 2-1/2 drop spindles up front and will turn the bars down! I need to go ahead and get wheels coming, after countless hours of looking I have decided upon black steel smoothies with the police cap! Now HELP.... I am thinking about 17x8 front and 17x9 rear and running a 3 inch wide whitewall, am I going to run into issues rubbing? what backspacing do you guys suggest?
