Old 08-20-2015, 01:06 PM   #1
68 IRON
68 IRON's Avatar
I6 PS conversion...confusion
I'm getting ready to do this upgrade to my 68. I want to also, while steering is the focus, to freshen up the steering parts (rod ends). This is where my confusion starts. Some who have done this are at odds with changing the idler arm...which is it truly? I also notice on trucks with PS equipped, the drag link is different from manual equipped trucks....should this be changed? And what is the difference between the adjustment sleeves, manual vs. power steering? And which should I order (manual, since that's what is on the the truck now)?
I have all brackets and pulleys (with pump) from one single previously operating vehicle...a complete set. The gear comes from a 72 GMC (w/ pitman arm). I'm just concerned with the other parts.
I hope someone can "steer" me in the right direction and focus me on what is a necessary change and what is not. Just help me bring this possibly overthinking stressed feeling I'm having right now down a notch or two!
68 IRON is offline   Reply With Quote
Old 08-20-2015, 03:51 PM   #2
NGN
NGN's Avatar
If it's a 68 with stock manual steering I would think the parts numbers would maybe different then for power steering , maybe you can use the numbers to compare if there is a difference . I think the gear box are all the same for two wheel drive as far as size.
Nick
NGN is offline   Reply With Quote
Old 08-20-2015, 04:26 PM   #3
michael bustamante
michael bustamante's Avatar
Re: I6 PS conversion...confusion
when converting to power steer using a square body steering box, you definatly have to change the centerlink. the pivot points are at a different angle than the one on your truck now. i believe the pitman arm is the same. are you going to be converting to disc brakes also? if so you might as well pull the whole steering rack from a 71-72 as the end links will be different from drum brakes
1967custom
michael bustamante is offline   Reply With Quote
Old 08-26-2015, 01:16 PM   #4
68 IRON
68 IRON's Avatar
No disk brakes at this time. So if the the center link gets changed, the drag link too I'm guessing....the whole shebang. It just got more involved....
Thanks for the info....I do appreciate it!
Old 08-26-2015, 01:32 PM   #5
michael bustamante
if youre keeping drum brake you still use your original steering linkage. dont change that. the power steer box will fit right on. i did this on my 67 and drove it for years
1967custom
Old 08-26-2015, 02:50 PM   #6
68 IRON
68 IRON's Avatar
Ok, to be clear.....I'm adding the PS brackets (which match my head), I'm adding a steering gear (from a 72 C10 with pitman) and I dont have to change any of the linkage from pitman arm on...is this correct? I thought you posted that the center link had to be changed because it was different. So if I dont have to change the linkage, I would love just changing rod ends to freshen this up.
Old 08-26-2015, 03:08 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
All you need to do is change the gear with the pitman arm. I have several used pitman arms here if you need one. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-27-2015, 12:40 PM   #8
68 IRON
68 IRON's Avatar
Ok....thank you Nick, Wes and Michael! I have the pitman arm that came with the gear, so I'm good. I do feel better now....
Old 08-27-2015, 01:12 PM   #9
michael bustamante
yeah that steering gear will fit right on. dont forget to reuse the pitman arm washer. (that gasket that sandwiches between the centerlink and pitman arm)
1967custom
Old 08-27-2015, 03:39 PM   #10
67 chevelle
67 chevelle's Avatar
The only different centerlink Ive run into is the power assist one [with rams], the power and manual are the same to my understanding
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
