Old 08-20-2015, 06:19 PM   #1
centuryhouse
centuryhouse's Avatar
can't get u-joint out of yoke / off rear drive shaft!
Is there a trick to this? I did this 20 years ago on a Mustang and it was easy. What gives??
I have removed the rear drive shaft on my 72 GMC pickup. I am trying to replace the u-joint mating the slip yoke to the rear shaft. I have removed 4 outer clips that retained the u-joint.
I used penetrating oil. I tried using a socket and hammering the u-joint out. I tried a c-clamp on it. It hasn't moved even the smallest bit.
centuryhouse is offline   Reply With Quote
Old 08-20-2015, 06:29 PM   #2
kingsolver72
10/30/19
kingsolver72's Avatar
Re: can't get u-joint out of yoke / off rear drive shaft!
Put the drive shaft in a vise. Get a large punch and a 5lb hammer.
Maybe a little heat also.
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 08-20-2015, 06:31 PM   #3
Taibo
Once the clips are out, a shop press is used to press one side INTO the the yoke, forcing the cap on the opposite side out so it can be removed, then just flip it over and repeat the process. Yours appear to have been attacked by a very large Hominid swinging a huge BFH, judging from the bashed up yoke. I am not sure that even using a press would allow you to change that joint now. If it were mine I would take it to a driveshaft shop and have the entire end of the shaft replaced.
Taibo is offline   Reply With Quote
Old 08-20-2015, 06:33 PM   #4
centuryhouse
I have a new yoke, ready to put on IF I can get the u-joint out.
Then once I have the car driveable, I was planning on taking it to a DS shop to have them fix up the shaft itself. I could have them do both, but as I've done it before I didn't think it'd be too hard.
I don't have a vice. If I wait 10 days for payday, I could buy one. I was hoping not to let the car sit another 10 days.
ETA: I also used a torch seeing if that would free it up. It didn't.
Old 08-20-2015, 06:45 PM   #5
kwmech
Just Take all the pieces to the DL shop and have it all done at the same time
Old 08-20-2015, 06:59 PM   #6
centuryhouse
I think that is the answer.
Their attitude was so poor (extremely rude and condescending) when I talked to them on the phone that I was hoping to just do this myself and limp by with it. The other DS shop in the area couldn't be bothered to speak English to me, and I couldn't communicate to them what I needed.
But I guess I'll go to the shop with the attitude and see if they can do it without being jerks.
Old 08-20-2015, 07:03 PM   #7
leddzepp
Moderator
leddzepp's Avatar
This ^^^
After reading countless threads on here concerning driveshafts, in the end, this is the best route. I have a slight vibration in my 72, removed the driveshaft yesterday and took it to the shop.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-20-2015, 07:36 PM   #8
jayoldschool
Moderator
Use a u joint/ball joint press.
You could do it with a big C clamp and two sockets (one to push in, one to let the opposite cup push out).
jayoldschool is offline   Reply With Quote
Old 08-20-2015, 07:54 PM   #9
brad_man_72
the boat guy
brad_man_72's Avatar
I wouldn't use a press, you could collapse a yoke. Vice will hurt/bend the shaft if you do it wrong. There's no way for a shop to give you an estimate over the phone, it sounds like you have some messed up parts, they don't know what might need to be replaced besides the ujoints and having the shaft balanced as an assembly.
Just take it to the shop. They can keep you from wasting time and money on a shaft that is in bad condition.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 08-20-2015, 11:50 PM   #10
Jason Banks
Jason Banks's Avatar
What shops did you talk to? Mine looked alot like yours. See where it looks like the yoke is dented from hitting the ground? That's what mine looked like when I pulled it after I ordered parts to fix it. I knew it wasn't going to be able to get it apart. I took it to the shop (Collin County Driveshaft...or something) on 380.
They used a sander or grinder or something to make the hole where the cap needed to come out round again. Maybe you want to try a Dremel with one of those little round sanding drums...
Jason Banks is offline   Reply With Quote
Old 08-21-2015, 12:45 PM   #11
centuryhouse
Update:
I took the rear shaft & parts to Drive Shaft King (Beckley Ave. in Dallas) during my lunch break.
They used a grinder to cut the u-joint into pieces, then hammered out the ends. They then opted to use their u-joint (not my O-Reilly part that I had with me) and installed it and the new Spicer yoke I had.
Total cost: $20 Total time: 15 minutes
That's pretty amazing, considering I will get a $20 refund from the O'Reilly u-joint I had, which the shop said was garbage.
Since the new yoke is 3" longer, it will engage the rest of the spline and should not slip off again (which was the original problem). I will put that back on the truck, and then drive it to the shop and let them assess & rework/balance both shafts as needed.
Old 08-21-2015, 01:26 PM   #12
boraxman
Keepin an eye out
boraxman's Avatar
^^^^^Great - love it when things go good!
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 08-21-2015, 02:02 PM   #13
centuryhouse
Me too! ;-)
Old 08-22-2015, 05:49 PM   #14
Taibo
Update:
GREAT NEWS! Glad it worked out so well for you. Without sounding condescending, a Spicer yoke will never go bad on you but who knows where the O'reilly part was made. Most likely China and you do not want that end of the shaft swinging around under your truck if it lets go.
Old 08-22-2015, 11:21 PM   #15
mike16
your yokes look a little beat up. all that peaned over metal could be preventing the capsfrom moving around enough to come off. Been there, used a dremmel to clean things up but eventually mine, lookin kinda like yours, ......had to be replaced.
another thing to look for. back in the day, I dont know when GM started this practice. but they had nylon plastic devices meltedin to the caps to prevent them coming apart. Dont kow what they called themor how it all functioned but it was a common practice on new cars with new ujoints.
the service manual reccommended aplication of heat, enough to visualy watch they nylon melt out from its hole. when you achieved that the u joint came out easy. skip that step and you will not get the u joint out. This applies to factory new installed u joints. if the u joint is NROS then the nylon has already been done away with.
good luck
mike16 is offline   Reply With Quote
Old 08-22-2015, 11:53 PM   #16
centuryhouse
There are 2 u-bolts and 4 nuts/washers that hold the rear u-joint in place at the rear differential.
Where can you get replacements for those u-bolts and nuts?
I notice mine keep coming loose after a few days of driving, and I have to keep tightening. I'm thinking about adding Loc-Tite. But I'd also like to replace them as they look pretty old and worn.
Old 08-23-2015, 12:17 AM   #17
69chevytrucker
69chevytrucker's Avatar
is it just me or is there a big a$$ dent in that shaft
69chevytrucker is offline   Reply With Quote
Old 08-23-2015, 01:44 AM   #18
centuryhouse
There is. Two actually. That's why I said next stop was the drive shaft shop. I brought that rear shaft in to them, and they told me to bring the truck so they could check out both shafts.
Old 08-23-2015, 01:49 AM   #19
leddzepp
Moderator
leddzepp's Avatar
They should be in the help section at any auto parts store.
I picked up my 2 piece driveshaft from the shop today. One of the things the tech told me was that those bolts only need to be torqued to 12 ft. Lbs. They should not come loose or need locktite.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-23-2015, 02:05 PM   #20
mike16
nappa sells the hardware to retain the u jonts
time to replace them if they are comming loose
Old 08-24-2015, 10:40 AM   #21
centuryhouse
Good to know, thanks!
Old 08-24-2015, 11:53 AM   #22
michael bustamante
michael bustamante's Avatar
i just picked up a spicer yoke for a 700r for 20 bucks new myself. sounds like i got a helluva deal. glad things worked out good for you
1967custom
michael bustamante is offline   Reply With Quote
Old 08-24-2015, 01:24 PM   #23
centuryhouse
You got out cheaper than I did for a yoke
Old 08-25-2015, 03:41 AM   #24
MikeyMan
Definitely get the shop to check out both the shafts.
You're probably out of balance and that's why your u-bolts & nuts are loosening.
MikeyMan is offline   Reply With Quote
Old 08-25-2015, 08:15 AM   #25
snipescastle2
snipescastle2's Avatar
Talking Re: can't get u-joint out of yoke / off rear drive shaft!
if it hasn't been said already, the factory injected plastic into the lock clip groove on the bearing caps on most vehicles back then, best to heat with a torch and press them out with either a vice and several sockets or a bearing press and/or a "C" clamp and some sockets. that should help.
Ben
snipescastle2 is offline   Reply With Quote
