Old 08-20-2015, 07:21 PM   #1
slepysal
slepysal's Avatar
motivate me !!!
Ok so I want to do my disc brake swap on my 60.
For those who have done this on there 60-62 with torsion bars , how long should it take? Any tips?
I have the spindles, rotors , calipers, hose , bearings etc. as well as upper lower ball joints and outer tie rod.
MOTIVATE me tell me it isn't that hard of a swap
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-20-2015, 07:29 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: motivate me !!!
It wouldn't be hard for me.
If you get stuck let me know and maybe I can come help.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-20-2015, 08:46 PM   #3
rcnutt
rcnutt's Avatar
Re: motivate me !!!
Put a 73-78 complete front crossmember in. With new booster/master cylinder...done
rcnutt is offline   Reply With Quote
Old 08-20-2015, 09:58 PM   #4
slepysal
slepysal's Avatar
Re: motivate me !!!
Thanks Im a fairly decent wrench just not sure if the Tbar was diffrent
I have all the parts for the spindle swap already
Old 08-21-2015, 11:08 AM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: motivate me !!!
The mechanical part should be fairly quick to do, depending on your tooling. About 4-6 hours total. The PITA part is swapping the MC to a dual style and pluming new hard lines.
Sorry if this wasn't motivating but trying to be honest.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-21-2015, 11:49 AM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: motivate me !!!
I have everything for the swap also.
Just haven't got around to it.
Fortunately I already split the lines and installed a dual ms. That was the first upgrade I did as soon as I bought her back.
I don't remember that being a PITA though.
Here's the thread I followed :
http://67-72chevytrucks.com/vboard/s...d.php?t=460791
66 C20 Service Truck:
Old 08-21-2015, 01:51 PM   #7
slepysal
slepysal's Avatar
Re: motivate me !!!
Outstanding !!! I split the brakes a while back so that's done. Thanks !
Old 08-21-2015, 01:56 PM   #8
slepysal
slepysal's Avatar
Re: motivate me !!!
I hear you !
Old 08-21-2015, 02:18 PM   #9
Chevy Fleetside
Re: motivate me !!!
The Thread said Motivate me. How can help not motivate you. I know you can wrench.
Old 08-21-2015, 03:13 PM   #10
slepysal
slepysal's Avatar
Re: motivate me !!!
But you did motivate me !!!
Old 08-21-2015, 03:37 PM   #11
chevy_mike
chevy_mike's Avatar
Re: motivate me !!!
Okay here you go.... Get off your butt and install those darn brakes!!!!
Need anymore motivation?
Old 08-21-2015, 04:47 PM   #12
morethanstock66
morethanstock66's Avatar
Re: motivate me !!!
If a repair task seems daunting to me, I always think about the end game. Get your mind into it. Picture how much nicer it will look, how much better it will perform. Then you also get to tell people that you did it when they ask. Plus, doing it yourself, you get to know your systems intuitively; so if anything breaks or leaks you have a good idea where it would be and how to fix it. Better performance, better style, peace of mind.
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 08-21-2015, 05:51 PM   #13
slepysal
slepysal's Avatar
Re: motivate me !!!
And there it is !!!!!
Old 08-21-2015, 05:55 PM   #14
slepysal
slepysal's Avatar
Re: motivate me !!!
Thanks . Ok looking at my calendar my next weekend off is Sept 12.
Stay tuned
Old 08-22-2015, 06:46 PM   #15
Gianyveedub
Gianyveedub's Avatar
Re: motivate me !!!
The only issue I had that stopped me for a while was the lower ball joints. If you go to Autozone, rent a tool to remove the ball joints form the spindle (not a pickle fork!!). I could not for the life of me get it separate and had to cut the ball joint out.
Check out my build and get motivated:
http://67-72chevytrucks.com/vboard/s...d.php?t=678272
Gianyveedub is offline   Reply With Quote
Old 08-23-2015, 01:20 AM   #16
doobiebro
doobiebro's Avatar
Re: motivate me !!!
Sal.. I'm afraid to say that most of your time will be spent removing the ball joints if your truck has the originals. Big pain punching out the factory rivets!!
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 08-23-2015, 10:37 AM   #17
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: motivate me !!!
My best advice on the rivets, shave the heads off, drill out at least 1/2 the diameter of the rivet most of the way thru and use a air hammer with a punch bit to drive them out.
Hope that helps with the motivation!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 08-23-2015, 12:11 PM   #18
slepysal
slepysal's Avatar
Re: motivate me !!!
thanks guys for the help
one question: Do I have to completely loosen the t bars, or can I just put the frame on jack stands and use my jack on the lower control arm to compress it like a normal coil spring ?
Old 08-23-2015, 12:28 PM   #19
61_FL_Apache
Who Me?
Re: motivate me !!!
Loosen them most of the way and all the tension will be off of them. With the wheels off the ground..
Steve
2001 Blazer 4D 2WD
Old 08-23-2015, 02:38 PM   #20
Gianyveedub
Re: motivate me !!!
I agree with 61_FL_Apache on the rivets. It does make it easier, but it is still a PITA. When I did the disc swap, all I did was put the truck on jack stands, I did not have to loosen the torsion bars. Have Fun...
Old 08-23-2015, 09:02 PM   #21
'63GENIII
'63GENIII's Avatar
Re: motivate me !!!
Getting that motivation is the hardest part sometimes. Once my projects get past the " ah, I could have it back together in an hour" point, thats what lights a fire under my butt. If you're close by, I could help if ya need. Im real good at taking other peoples stuff apart! Lol.
Let me know if you need a hand.
Chris
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-03-2015, 06:58 PM   #22
slepysal
slepysal's Avatar
Re: motivate me !!!
Thanks again for the motivation . I hope to start on it Monday. Just in case I don't finish I took Tuesday off too.
I will try to take a photo log as I go.
Old 09-09-2015, 06:40 PM   #23
slepysal
slepysal's Avatar
Re: motivate me !!!
So close !!!! Almost finished , just need to install the booster/ master.
I picked the hottest week to work on the swap !!
