Old 08-20-2015, 08:02 PM   #1
revjames
Need e brake help
I need help. I rebuilt my new rearend from a 71 c10 it's a 12 bolt. I have a 63 can and frame it is going to attach to. However the rear end does not have any e brake cables etc. what would be my best course of action to get some. Are they the same do I look for 63 e brakes or 71??? Thank you so much you guys have been such a help this far.
revjames is offline   Reply With Quote
Old 08-20-2015, 09:33 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Need e brake help
Look at Inlinetube.com. They have the parts you need. Order stuff for a 1971 rear and convert your 1963 ebrake system to a 1966 and up version. It does away with the 1963 factory ebrake crossmember. I'm assuming you have a 1963 Chevy with rear swing arms.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-20-2015, 10:26 PM   #3
revjames
I do have a 63 Chevy with rear control swing arms. I do not however have a transmission crossmember at this time. I was just going to order a tubular one. Am I correct in assuming your saying if I upgrade to a 66-72 parking brake setup I do not need the crossmember linkage though
Old 08-20-2015, 10:41 PM   #4
Lugnutz65
Lugnutz65's Avatar
I think the 1963 Chevy frame has an ebrake crossmember crossmember like the 1964-65. In 1966 they changed the ebrake cable system and eliminated the ebrake crossmember.
I am NOT referring to the transmission crossmember under the bell housing.
Here's a few pictures of my 1965 ebrake crossmember and frame. It's covered in grease and dirt under the drive shaft. I cleaned it up and the put it back in place when I was mocking up my conversion to the 1966 ebrake cable system.
Old 08-20-2015, 10:47 PM   #5
revjames
Thank you I got it appreciate the help and experience
Old 08-21-2015, 10:56 PM   #6
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Hi revjames.
I'm not sure if you're aware that the Panhard Bar mount location on the '71 rear axle housing is different than the original '63. I had to deal with the same issue on my '63.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 08-21-2015, 10:59 PM   #7
revjames
I was not away of this. What did you have to do differently
Old 08-22-2015, 01:06 AM   #8
Johnny_Lamebridge
I wasn't aware that my rear axle had been changed. When I lowered my C10 (5"), I bought an adjustable Panhard Bar from CPP. When I went to mount it, I found it was too long, and if shortened it would hit the Diff cover.
After doing a little research here on the forum I learned that the Panhard Bar setups in 63-64 are different than 65-72's. I ended up modifying what I had...check my build thread below, posts 87 thru 89.
I imagine the easiest fix would be to change the Panhard Bar frame mount on your truck to a 65-72 style, then use the 65-72 Panhard Bar. I'm sure lots of guys have done this.
