08-20-2015, 09:04 PM | #1 |
Rear air bag - axel or trailing arm
I am going to put a notch in the rear of the frame of my 1966 and I am wondering where to place the bags. I have seen amazing builds with bags on top of the axel. I have seen others with the bags on the trailing arms. What are the benefits of mounting the bags on the arms vs putting them on top of the axel? I have slam specialty 7 bags if that makes a difference.
08-20-2015, 09:21 PM | #2 |
Re: Rear air bag - axel or trailing arm
I have a pair of SS7's and plan to put them where the coils are. I don't see any benefit in deviating from the GM design, but I don't plan to notch or "lay frame".
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
08-20-2015, 09:31 PM | #3 |
Mine are currently mounted in the stock spring location. I am planning on laying frame, that is why I am putting the notch in.
08-21-2015, 08:28 AM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
I dont have a notch and my bags ( firestone 2600) are in the stock spring location and I have the bag cups installed. I did this for towing and not laying frame although it does give me that nice lowered look that I was looking for.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-21-2015, 09:50 AM | #5 |
Stock spring location with stock and PORTERBUILT arms.
Don't really need notch, pumpkin pokes through before axle.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-21-2015, 09:51 AM | #6 |
I just uploaded before pics on my build thread. See link in signature. I am a little nervous cutting into a perfectly good frame, but what is the worst that can happen???
08-21-2015, 09:53 AM | #7 |
Pipe notched.
08-21-2015, 09:56 AM | #8 |
Thanks for the pictures. I am planning on raising the bed to accommodate the pumpkin.
Based on measurements I took before I took the bed off, with the axle touching the frame, the bed is 11 inches off the ground. So I figure I need to have about 12 inches of notch. I want the axle to bottom on a bump stop, not the frame. |
