08-21-2015, 12:46 PM | #1 |
Help with I6 valve cover gasket.
Saw a video on YouTube by Scared Shiftless, and old dude was saying TO NOT USE SILICONE. He said to use spray glue on the valve cover said and the gasket, make sure they are dry, and isn't the bolts hand tight plus a good half turn, using a CORK GASKET. I heard use Rubber gaskets, he said Rubber Gaskets suck, my mind is blown, please share your advice and opinions because I replaced my valve cover gaskets and I'm getting leaks again so I patched them up with silicone -,- I used a fork gasket because NAPA didn't have rubber. Should I buy a new cork gasket and do it again using glue?? Help!
08-21-2015, 01:00 PM | #2 |
Moderator
Re: Help with I6 valve cover gasket.
I just replaced my gasket after doing a new rocker nut. Used rubber, no glue. No leaks.
08-21-2015, 01:05 PM | #3 | |
So you want to know which is best? Check the FSM to see what Chevy used from the factory. Cork will be ok. So will rubber. Proper installation is much more important than anything else. You will find many differing opinions.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
08-21-2015, 01:11 PM | #4 | |
08-21-2015, 01:13 PM | #5 |
I was thinking about getting the Offenhuase aluminum valve cover but I saw that it doesn't have an outlet for the PCV valve.
08-21-2015, 01:21 PM | #6 | |
08-21-2015, 06:48 PM | #7 |
When I get them when they have been over tightened I put a socket on one side with a bolt through the hole to the other side, put a nut on and tighten until it is straight again.
Then a thin smear of silicone on one side of the gasket, lay it in the channel, thin smear of silicone again on the other side and set it down with bolts barely more than finger tight. Next day another half turn and it is good to go. |
08-21-2015, 06:54 PM | #8 |
I used rubber gaskets on my 292 with no problem. Just DON'T tighten the CRAP out of the bolts! Hand tight is almost enough. Silicon will help for sure. I have heard bad things about the offy so I'd be careful getting one.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-21-2015, 07:56 PM | #9 |
Moderator
I should also mention that I took out my body tools and made sure the cover flange was straight as an arrow.
08-21-2015, 10:09 PM | #10 |
Thank you everyone for your reies! I've been F work but I've been reading them all day, I got myself a wooden block from work and when I buy the gaskets for dirt cheap from RockAuto, I'm gonna straighten out the valve cover, I think that is my Issue, I'm gonna go with Rubber this time as well, I have cork in there now. I'm also missing one washer as well,
08-21-2015, 10:49 PM | #11 |
I know that this isn't a valve cover but I just changed the filter and gasket on the powerglide transmission in my Chevelle. I know it may sound wrong but the instructions that came with the filter kit (rubber gasket) said to clean both mating surfaces and make sure that the pan was straight. Then apply a thin layer of grease to both sides of the gasket and install the pan torqueing it in a criss cross pattern. First to 80 inch pounds then a second time to 120 inch pounds. That was about 3 weeks ago and so far no leaks on the garage floor.
