Old 08-22-2015, 06:11 PM   #1
roger55
roger55's Avatar
Clips for trim at the rear of dash top on '57 question.
The clips that came off before my restoration appeared to be in good shape so I decided to not get new ones.
However, the trim isn't holding down as tight as I'd like it too. Loose in a couple of spots and would sure look better if it was more tightly held.
Will new ones solve the problem? Anybody else have this issue with suggestions for me?
I was looking at the Brother's site and the photo of the clips they have look a slightly different shape than mine.
The ears that go into the trim on theirs look they curve and the ones I have are flat.
roger55 is offline   Reply With Quote
Old 08-22-2015, 11:02 PM   #2
paulspickupparts
Re: Clips for trim at the rear of dash top on '57 question.
Pretty common problem with used clips. I have never used any of the repo's so cannot vouch for quality. You might take it off and try to rebend the orgiinals. They often get bent or tweaked when removing and then on re installation they will not pull down tight.
paulspickupparts is offline   Reply With Quote
Old 08-23-2015, 08:19 AM   #3
joe70
joe70's Avatar
classic inds.carrys a set of 8 for 9.99 part #559278
joe
joe70 is offline   Reply With Quote
Old 08-23-2015, 09:42 AM   #4
roger55
roger55's Avatar
Thanks Paul. I'll get new ones. I tried bending but it didn't help much. The are too hard to bend being so small. Not worth the time if a new set does the trick.
Thanks Joe. Brothers has them for $7.99 and I'm making up an order right now with them and other items I need.
Old 08-23-2015, 12:43 PM   #5
1project2many
Might check the receiving half on the dash. The flats will sometimes bend "up" when the trim is removed. Tap them back down using a screwdrver or piece of wood. I used grease on the clips when I installed my defroster trim hoping it would make a future removal easier.
1project2many is offline   Reply With Quote
Old 08-24-2015, 02:09 AM   #6
tmoble
mine broke last time I tried to bend the tabs. metal was brittle.
tmoble is offline   Reply With Quote
Old 08-24-2015, 07:29 AM   #7
1project2many
That's a tough one if the truck is together and painted. I'd probably try to build a piece to slip over that bracket snugly and use 2 part body adhesive to secure it.
Old 08-30-2015, 11:44 AM   #8
roger55
roger55's Avatar
The clips I got from Brothers worked well.
The molding is snug now.
Old 08-30-2015, 03:57 PM   #9
1project2many
Looks good.
