08-22-2015, 08:41 PM | #1 |
Carter Weber carb problems!
I added two carter weber carbs to my 235 and I can't get it to run at full power. I only get fuel to one of the barrels on both carbs and when I hook up the electric choke the engine dies. I already removed the top of the carbs and I cleaned out the jets but still no luck. When i first put the, on I had full power and the truck ran great but the new fuel pump went out and then it never ran the same. Any help would be great!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
08-23-2015, 10:43 AM | #2 |
Re: Carter Weber carb problems!
The new fuel pump went out? So what pump do you have on there now?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-24-2015, 09:28 PM | #3 |
I got a new one from classic chevy. It's running now!
08-25-2015, 11:02 AM | #4 |
Any increases in power that you noticed with the dual carbs? Worth the effort? I wanna see a video! lol
08-25-2015, 12:38 PM | #5 |
It's has a increase in power and you definitely can feel it when you take off. It runs and drives smother than before when I had the 1 Barrel on it. I was out driving it yesterday and got so carried away I nearly lost it in a turn. TJ what do you want to see on the video?
08-25-2015, 05:41 PM | #6 | |
