Old 08-23-2015, 10:45 AM   #1
LT1 Burb
LT1 Burb's Avatar
Need wiring help, pics!
So I bought an AutoWire OEM wire harness and need a little help, I have one extra taillight wire that I don't know what it is. I am thinking reverse lights or it needs to be peeled out of the harness. Also anyone know where the grey and pink wires for the factory tach get plugged in, I am thinking at the fusebox but don't know for sure. And is my 2 speed wiper motor wired correctly, thanks again.
LT1 Burb is offline   Reply With Quote
Old 08-23-2015, 11:38 AM   #2
63 Spud
63 Spud's Avatar
Re: Need wiring help, pics!
The wiper motor wiring looks right, same as mine and it works correctly. The green wire is for back up lights on a '66. There would be another hole in your firewall below the existing hole if yours was a '66. I can't help with the tach wires, can't find a wiring diagram that shows a tach. BTW great job on your build. I wish mine looked as good!
Mark
'63 C10 short step
63 Spud is offline   Reply With Quote
Old 08-23-2015, 11:57 AM   #3
HOTFUN
HOTFUN's Avatar
On the tach just plug pink wire into the unfused left side of the 3 amp radio fuse. The gray wire is the dash lamp plug it into right terminal for panel lights. It just needs to be hot with the key on not all the time of course. The green wire is your backup wire and that is the 66 style harness. If you want backup lights I believe that connector just attached under the steering column area to a wire running in the dash when used an accessory. Otherwise just peel it out of the front to back harness.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
Last edited by HOTFUN; 08-23-2015 at 12:41 PM. Reason: correct pink color wire location
HOTFUN is offline   Reply With Quote
Old 08-23-2015, 12:10 PM   #4
LT1 Burb
LT1 Burb's Avatar
Originally Posted by HOTFUN View Post
On the tach just plug it into the side with the 3 amp radio fuse. It just needs to be hot with the key on not all the time of course. The green wire is your backup wire and that is the 66 style harness. If you want backup lights I believe that connector just attached under the steering column area to a wire running in the dash when used an accessory. Otherwise just peel it out of the front to back harness.
Thanks Spud, so Hot Fun, in 65 if back up lights were ordered do you know how they were run.
Old 08-23-2015, 12:10 PM   #5
HOTFUN
HOTFUN's Avatar
Went down and snapped these pictures. The 65 accessory manual shows drilling the 1/2 hole 1.5" below tail lamp plug on firewall too. Otherwise you can see my dash wire ends in the two respective dash holes on a 1966.
'72 GMC K2500 4x4
Old 08-23-2015, 12:26 PM   #6
HOTFUN
HOTFUN's Avatar
More detail of my busy fuse cluster. I have a lot of accessories such as radio, tach, clock, cig lighter, and factory park brake alarm plugged in. Also second picture is inside cab of tail lamp wire and the backup lamp wire going through dash mat above gas pedal.
'72 GMC K2500 4x4
Old 08-23-2015, 12:40 PM   #7
LT1 Burb
LT1 Burb's Avatar
That helps, thanks. I don't know why I couldn't find the backup light section in my assembly manual, maybe because the way its put together is a disaster. Its like they took all the pages, threw them up in the air and then bound the book together.
Old 08-23-2015, 12:46 PM   #8
LT1 Burb
LT1 Burb's Avatar
Here is a pic of mine, I have this green wire I need to trace out, I think it's the backup light that needs to jump over to the firewall, I can't imagine it needs to be plugged in to the fusebox.
Old 08-23-2015, 12:55 PM   #9
pimpston65
pimpston65's Avatar
so what your really saying is you bout to be driving soon!!! great progress. im still hate'n
pimpston65 is offline   Reply With Quote
Old 08-23-2015, 08:31 PM   #10
LT1 Burb
LT1 Burb's Avatar
Not quite, but my goal is to get it running so I can move it around.
