08-23-2015, 09:58 PM | #1 |
5 lug disc brake identification
the PO decided to convert my truck to the front drums to 5 lug disc, and the only identifiers on the rotors were '24.5, 14008647, 9D/15 (stamped upside down and backwards), K1, and the word 'MINTHICK'
Anyone have an idea what these could be from? I need to replace the pads as soon as I can.
White 1966 C10 LWB Fleetside 1983 Mercruiser Marine 305 V8/Chevelle 4spd "Ellen of Truck" |
08-23-2015, 10:13 PM | #2 |
Re: 5 lug disc brake identification
I believe it's saying minimum thickness is 24.5mm
08-24-2015, 01:13 AM | #3 |
60-66 Nut
They are likely just '71-'87 front brakes which use the D52 pads. Also they are the light duty 1" thick rotors which I believe were used more commonly in the 80's.
08-29-2015, 03:05 PM | #4 |
Awesome, thanks guys. I'll call napa on monday and try to find them.
09-05-2015, 05:05 PM | #5 |
The brake set was a 1975 truck. Thank you so much guys.
