![]() Join Date: Jul 2010
Nearing completion
I am very near completion of a very long project with my 69 suburban. I am waiting on the seat covers to come in, been 6 weeks, but then again, they are sewing up three seats. I also need to decide what to do about the headliner, FRP or something else? I know the interior door panels are from a 72, but I liked that better than what was optioned in 69. I used SEM products to restore all of the door and back panels.
I paid lot of attention to sound and vibration control. I used MLV decoupled with foam and did a DIY lizard skin in all the doors and behind all the back panels. Paint was done in my garage with a DIY booth. I brought it back to factory colors of Saddle Metalic and White. I am saving up for Mar K lower moldings to offset the two tone at the bottom This forum was a valuable resource for parts, ideas, troubleshooting and countless other accolades. Looking forward to the first drive in more than 5 years as soon as the seats come in.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() Last edited by magicoolbus; 08-23-2015 at 11:41 PM. Reason: spell |
The Older Generation
Re: Nearing completion
Looks really good! The colors set everything off, that's for sure. LockDoc
Thanks Leon
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
Wide n'Low
![]() Join Date: Jan 2007
Awesome!
that looks killer. Would certainly be interested in finding out details of the build.. I can also feel for you on how long it takes to get behind the wheel and drive one that has undergone such a transformation.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
![]() Join Date: Oct 2012
Man that thing looks good, nice work.
#6 | |
I hope mine looks as nice as yours when I get to the paint part |
Strongman Garage
![]() Join Date: Apr 2000
Love the color!
I had a similar gas tank under the back seat in my suburban. I guess it was a common? Also what color is that carpet and where did you get it?
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
Looks great! If this took you 5 years i'd say i'm about 4 years and 11 months away from completing mine. HaHa The progress is never quick enough but the reward is amazing. I like that you kept it original. Nice job!
![]() Join Date: Feb 2011
That is very sharp!!! Nicely done
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Very nice, how about some pics showing the process.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#11 | |
The carpet is the saddle brown available from many sources, got mine from brothers during one of their sales. But the carpet is made by ACC.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() Last edited by magicoolbus; 08-24-2015 at 08:46 PM. Reason: added picture |
Here's a before, during and after shot of interior. In the before, you can see the DIY lizard skin. I used white elastomeric roof compound and added 'micro balloons (spheres) and water to thin. Using a undercoating gun sprayed two coats to about 3/16" thick. Did this in the doors too.
Picture 2 is epoxy primer, and then lastly is Saddle Metalic, PPG code 2101. You can also see the rear a/c lines that I ran. The rear floor was in very good shape and I freshened it up as recommended in the Mar K wood finish test. Used POR 15 and Black Oil Base House paint. http://www.mar-k.com/wood_finish_testing_ii.aspx
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() Last edited by magicoolbus; 08-24-2015 at 09:11 PM. Reason: added picture |
#13 |
Lots of man hours !! Great job.
#14 |
That looks awesome!
I'm getting ready to start the interior of mine, didn't even occur to me to paint the wood in the back. Duh! How did you stick the MLV down? Spray adhesive? Or did you just cut it and set it in there? |
#15 |
Thanks for the extra pics. You did a great job and I really like the color with the parchment.
#16 |
The foam I used was self adhesive. I used 3M 90 spray adhesive to hold the Mass Loaded Vinyl down. The carpet from ACC had a jute padding as well in the footwells for the front and center seats.
#17 |
Here's a tip that I figured out myself, but I am sure that others have probably done something similar. When making holes in the carpet for seat installation, seat belts, dimmer, trans shifter etc, I did not use a carpet knife or razor. I used an old soldering iron, it worked like a hot knife and sealed the edges at the same time. It puts out fumes, so I used a paint respirator, but worked very well. Just make sure the carpet is in its final position before committing yourself. A helper is very nice here to push up from underneath to ensure correct placement, just tell them to get their fingers out of the way before burning through.
#18 |
Here's a better angle of the nearly completed dash. I used white gauge vinyls that are available on ebay. Also used his black lettered dash lens. Added a tach and vacuum. I added a rear air switch below the light switch, that is pretty hard to find item, some say it may be made of unubtainium, but patience and this board were helpful. I also added a wiper delay available from a board member here. It was a very easy install and I made my own switch location right below the normal wiper switch. Looks kinda factory I guess.
I repurposed the grant steering wheel that I had already, just scuffed the black paint and shot it in saddle metallic. I did a custom horn button, found a bowtie emblem that fits my personality and heritage and used jewelers resin to finish it off. I redid the shift knobs too. Cleaned out the paint and crud from the shift pattern, Sanded it to a smooth finish, shot a black base coat, then misted a few coats of white over the shift pattern, took a 1000 grit and sanded off the white 'overspray' and cleared with H/S urethane. Still waiting on my radio, hence the center a/c and glove box not being installed.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() Last edited by magicoolbus; 08-25-2015 at 11:27 AM. Reason: added picture |
#19 | ||
#20 |
Nice! Hope to see you driving it around the Phoenix area soon.
#21 |
BlahBlahBlah
Beautiful job! I really like that color.
Im curious what mass loaded vinyl is, never heard of it.
#22 |
MLV is basically a modern substitute for "lead lined." It is quite heavy, my roll was of the 1/2 pound per square foot variety and it is about 1/16 inch thick. It also comes in the 1 pound per. Very effective at sound control. I am using a pretty loud exhaust and wanted as much reduction as I could get, also wanted to eliminate any resonations. In all my research, it looked like 'decoupled' MLV was the way to go. Lot's of articles on it on the WWW.
#23 |
The gauge vinyl and replacement lens came from white gauges, url below. Lots of how to on their web site as well.
http://www.whitegauges.net/products/...ment-Lens.html
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() Last edited by magicoolbus; 08-26-2015 at 12:00 AM. Reason: typo |
#24 |
Howdy JB,
As soon as you are ready to go play in the dirt there are a a couple of Phoenix area Burbs (me and Mosesburb) who are always happy to have another traveler along. Tons of killer local trails, great weekend getaways and more history than most folks realize. Very nice job on your build also. |
#25 |
![]() Join Date: Jul 2012
Very nice! Thanks for sharing details. I need to do some sound control on the wood in our Burb and will check into the MLV.
