Old 08-24-2015, 08:06 AM   #1
yoshi
yoshi's Avatar
MII front wheel bearings
Do you think these are ok? Anyone used em? Thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 08-24-2015, 10:34 AM   #2
mr48chev
mr48chev's Avatar
Re: MII front wheel bearings
If you have a quality brand bearing you won't have an issue.
The outer bearing is the same outer bearing that is in 80 % of the rear wheel drive Ford cars ever built.
If this link will open for you the compatibility link shows what the bearing fits.
http://www.oreillyauto.com/site/c/de...0055&ppt=C0337
Note there are two different inner wheel bearing sets depending on what ring gear the rear axle in the car had. Only Ford would come up with something like that.
They are a National or BCA A13 or an A5 set.
A 13 measurements
Cone Bore (In): 1.377 Inch
Cone Bore (mm): 34.981mm
Cone Length (In): 0.660 Inch
Cone Length (mm): 16.764mm
Cone Part Number: L68149
Cone Radius (In): 0.203 Inch
Cone Radius (mm): 5.156mm
Cup Length (In): 0.470 Inch
Cup Length (mm): 11.938mm
Cup Outside Diameter (In): 2.328 Inch
Cup Outside Diameter (mm): 59.131mm
Cup Part Number: L68110
A 5 measurements
Cone Bore (In): 1.375 Inch
Cone Bore (mm): 34.925mm
Cone Length (In): 0.720 Inch
Cone Length (mm): 18.288mm
Cone Part Number: LM48548
Cup Length (In): 0.550 Inch
Cup Length (mm): 13.97mm
Cup Outside Diameter (In): 2.562 Inch
Cup Outside Diameter (mm): 65.088mm
Cup Part Number: LM48510
There is a .056 MM difference in the Inside diameter of the cone.
Again either of those bearings are used on much larger and heavier vehicles than the MII so there isn't an issue with using the bearings on an AD truck.
My ongoing truck projects:
Old 08-24-2015, 10:56 AM   #3
yoshi
yoshi's Avatar
Ok thanks are they not a quality brand? How tight a fit should there be between the inner bearing & spindle? Should it slide on or need a bit of tapping? Also do I need the outer ring as there is a brand new one in side the new rotor/hub? Thanks
yoshi's 49 project
Old 08-24-2015, 11:46 AM   #4
67GMCkid
67GMCkid's Avatar
No picture what brand are they?
Didn't you just pick up new rotors a few weeks ago ?, if so you may want to check with who ever you bought them from, a lot of the 11" rotors being sold for the m2 conversions are Ford Granada rotors drilled for the chevy 4, 3/4"
bolt pattern. If you have a set of these rotors they use a,
NATIONAL A13 Inner
Taper Bearing Set; Cone Bore=1.3772", Cone Length=0.66", Cone Radius=0.203", Cup Outer Diam=2.328, Cup Length=0.47", Cup Radius=0.05" Front
NATIONAL A12 Outer
Taper Bearing Set; Cone Bore=0.8661", Cone Length=0.655", Cone Radius=0.05", Cup Outer Diam=1.781, Cup Length=0.475", Cup Radius=0.05
67GMCkid is offline   Reply With Quote
Old 08-24-2015, 12:14 PM   #5
yoshi
yoshi's Avatar
Yes I've just got new rotors from speedway, they say
"Works with Mustang II/Pinto and Granada rotors using Mustang II/Pinto spindles only. It will not work for installing Mustang II/Pinto brake rotors on 1949-1954 Chevy spindles. Not for use with early Chevy spindle brake conversion kits.
-Large Bearing-
Thickness: .656"
Upper OD: 1.900"
Lower OD: 2.150"
Bearing ID: 1.375"
-Small Bearing-
Thickness: .651"
Upper OD: 1.380"
Lower OD: 1.570"
Bearing ID: 0.864"
Never install new hubs with old bearings.
Item Details
For Mustang II/Pinto and Granada rotors using Mustang II spindles."
yoshi's 49 project
Old 08-24-2015, 12:19 PM   #6
_Ogre
_Ogre's Avatar
all machined parts have tolerances, while bearings have very close tolerances, the spindles may have a + from a few thou to a few hundredths
typically wheel wheel bearings should slide on without tapping, but have no play
if there is a little looseness, green loctite is sold as a bearing retainer
we used it often on industrial machining equipment, where ironically we made truck axles and spindles
shop air compressor timer
Old 08-24-2015, 01:29 PM   #7
67GMCkid
67GMCkid's Avatar
My m2 kit came with some garbage Masterpro or master something or the other. Yes they were very tight on the spindle the first few times on and off.. I am only using them to keep the wheels on for now so I can move it around, before it hits the road it will have a much better grade in it.
Old 08-30-2015, 11:00 PM   #8
mr48chev
mr48chev's Avatar
Our dilemma and tight or loose inner bearing to race issue is all due to Ford's penchant for making different setups for different applications that are totally meaningless but give the engineers in the cubicles a pass to work for another year because it looks like they did something. That .056 diffenence for the inner bearing could be a killer for someone who doesn't know it even exists. And until I did some homework on MII wheel bearings I didn't.
