![]() Join Date: Jan 2012
Frustrated! Glass install
Took my 71 to have new front and back glass installed. Guys show up at my Granddads body shop to do it and refuse to touch it when they realized it had the stainless trim. I had specifically called these guys to do it because it had the trim in it. They said they had messed up a guys trim and had to replace it and wouldn't touch another one. Now what am I gonna do?
Re: Frustrated! Glass install
Do it yourself, (with a buddy...your granddad?). read up on it and go slow. Use plenty of soap...I use Windex.
This is probably what I am going to hafta do. Was trying to save time and have it done. My grandad is 81 and has done several and has an old buddy that was a Chevy mechanic for over 30 years that has done them back in the day so will prolly hafta go that route.
![]() Join Date: Mar 2015
![]() Join Date: Dec 1999
You can do it. They probably got in in a hurry on the one they messed up.
Yes I have watched it guess I will be doing it myself.
Still Learning
Harpie,
My son and I did my front and rear. Start with the rear window, get a little confidence before tackling the front. Take your time and use plenty of soapy water or windex for lube. I bought a piece of 300 paracord to mine. It worked pretty good. It is still very nerve racking... good luck. Man, I wish I had seen that video before I installed mine. Thanks for sharing that. |
Old member
My daughter and son helped me. We did both front and back in a couple of hrs. No leaks in 5 years so I guess we did Ok. Just take your time and be easy with it.
I used some plastic knifes to help get the corners in right and cord inside the gasket to pull the gasket through the opening. As stated use plenty of soap. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
thanks for the advice we are going to give it a try... wish me luck
Wow, I watched that video. Most mortals would break the glass trying to get it out as demonstrated. I think that guy came really close to breaking the windshield. I recommend cutting the original rubber seal so the glass almost simply lifts out. And, finally, soap or Windex would have made the install soooo much better. Another tip, might be to ensure you put upward pressure on the windshield while you work the rubber seal over the pinch weld. gravity tends to pull the glass too low...so keep working it upward as you work it in.
Good luck. |
Took me and my dad three times till we got one in without breaking it, Its a learning curve for sure lol
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
remember: practice makes perfect or you go broke. Either way, there's incentive.
#13 |
![]() Join Date: Mar 2013
Take your time, use lots of lube. Suction cups help, as you can pull in while pulling the rope out. Honestly, the biggest hurdle you have is make darn sure the trim doesn't pop out as you are installing it. If it does, start over.
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
#14 |
the assembly manual also shows that some adhesive (butyl rubber?) should be used at the corners. I haven't seen much discussion on the board about this though.
#15 | |
![]() Join Date: Jan 2001
I also second (or third) the use of glass cleaner as a lubricant. It's slick enough to work and doesn't leave the mess that dish soap can. |
#16 |
![]() Join Date: Apr 2015
https://youtu.be/i2Xg30Q39Cw I watch this vid..
#17 |
Harpie you need help let me know . My numbers 580 380 3101 ill give you a hand anytime you need it brother
#18 |
#19 |
#20 |
My 2 sons helped me put mine in. We did the back one first to get the hang of it and then did the front. Took all of 15 minutes and the rubber lays flat perfectly.
There are lots of people that will tell you to pull the top in first but we couldn't get it in that way. We pulled the bottom in first and worked each side around a little at a time toward the top. Use a circular motion when you get to the top corner while pulling the rope to help it around the 90 degree corner. I had the boys press on the outside with a flat hand as I pulled on the rope. Use lots of soapy water, I used a couple drops of dish soap in a spray bottle of water and soaked the rubber and pinch weld really good. Don't be afraid to tackle this on your own. Watch the video and get two helpers and have at it. Good luck.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
#21 |
I took mine to safelite auto glass . They ordered the rubber and the chrome trim to ensure fit. It cost me $250.00 . I tried it myself the first time ! Ill never do that again. Its way harder then the videos look and what anyone says. You'll probably break the windshield like me. Just call around and make sure you get the rite parts.
#22 |
I found a company willing to do it for $250 but I hafta haul it to the shop and leave it for a day. But if they break anything they will replace it they said. So looks like that's what I am going to do.
#23 |
![]() Join Date: Mar 2012
I did not realize there were that many Oklahoma peanut farmers on this site??? LOL
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
#24 |
Yeah you best watch us peanut boys !!!!
#25 |
LOL, I had family in Kingston /Madill area
and my dads side are from the mill creek/Tishomingo area I grew up in Moore,Ok
