?? about wood bed
im putting a new oak wood bed in,,,, ive got all the wood and bed strips,,just need to know exacally what kind if varnish to put on it to make it look good and preserve the wood,,,and where you can get it,,,, thanks
I would use marine grade spar varnish or spar urethane. I know the urethane comes with UV protection and resists moisture and temperature changes. One important point. Before sealing up the wood make sure that it is dry, dry, dry. Any moisture trapped inside could cause problems later on by rotting from the inside out. This stuff is available at most hardware stores.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
http://public.fotki.com/street
Spar Varnish will hold up the best wit uv rays. Regular urathane won't take the sun
I am at this stage also, and i was wonering how well it would work if i put a clear coat on that you would normally use on paint jobs and whatnot. Is this a good or bad idea.
Post Whore
![]() Join Date: Feb 2000
I haven't done a wood bed but I know you need to finish the top and bottom. I would assume you also want to finish the sides too.,
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
finish
You can buy at Lowes $30.00 a gal
Anybody have a stash of Penta somewhere?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Anyone remember when Stacy David started Copperhead, he finished an oak bed kit? It wasn't for his truck, but he showed how to do it. I can't find the show number, or the products he used.
U.S.A.F. 68' C-10 Stepside 305 w/ 4 speed |
