Old 08-24-2015, 01:25 PM   #1
Coldshot
Coldshot's Avatar
47-53 solid windshield swap???
Hey guys, I've done a quick search and can't find what I think I've seen before somewhere. Swapping out the split windshield on a 1947 to 1953 truck to the 1954 solid one.
Is it as easy as taking out the center strip and cleaning up the seal edge and just put the new glass in or does the other glass need more rework of the window frame??
Coldshot is offline   Reply With Quote
Old 08-24-2015, 01:27 PM   #2
lv2tri2
Re: 47-53 solid windshield swap???
54 glass will not fit 47-53. The cab is different.
lv2tri2 is offline   Reply With Quote
Old 08-24-2015, 01:56 PM   #3
67GMCkid
67GMCkid's Avatar
There are one piece windshields available for the 47-53 cabs .
Here is an old thread,
http://67-72chevytrucks.com/vboard/s...d.php?t=449475
67GMCkid is offline   Reply With Quote
Old 08-24-2015, 03:08 PM   #4
Coldshot
Coldshot's Avatar
Thanks guys, kinda what I thought.
Found a solid for cheap but the glass for these trucks isn't expensive anywho
Old 08-24-2015, 05:24 PM   #5
47 Fasttoys
47 Fasttoys's Avatar
Actually glass may be even cheaper then you think: when I ordered my windshield from Classicparts I ordered 2 thinking 1 for each side, nope 2 means 2 pairs. At $39 or $49 I just held on the the extra, so not only can you get a windshield for under $100 but you can get 2 for under $100.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 08-24-2015, 05:43 PM   #6
mr48chev
mr48chev's Avatar
as lv2tri2 said the 54 glass won't come close to fitting as it is curved and the 53 and earlier is flat.
As far as the aftermarket single piece glass for 47/53 I'd seriously suggest seeking out a couple of trucks at shows that have those windshields in them and looking closely at the glass and especially through the center where they bent it. The one I see fairly often at local events has an extreme amount of distortion in the glass at the V in the middle.
My ongoing truck projects:
Old 08-24-2015, 06:52 PM   #7
Coldshot
Coldshot's Avatar
Yea I'm pretty happy when I look at new glass prices. From my local shop I can get every peace of glass for $300
Old 08-25-2015, 04:59 PM   #8
whitedog76
Find a 54/55 1st series cab.
whitedog76 is offline   Reply With Quote
