![]() Join Date: Dec 2014
Guys with ece mounts?
Does your motor sit this far forward? I think I'm gonna buy some dirty dingo mounts to get it to sit further back.
Re: Guys with ece mounts?
![]() Join Date: Dec 2012
This is my install with the ECE mounts like you have. I am not sure if but I think I am farther back than your install. Maybe the mounts your frame are farther forward than mine.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
6 cyl VS 8 cyl location? Just a guess.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
AOD - those frame stands don't look factory. it also looks like someone notched your frame to fit those in?
Instead of sliders @ $150+, you could pick up a set of regular 3 position plates for around $50 |
These stands came with the ece mounts. I thought it was a factory stand. I just ordered some dirty dingo mounts to see if that will push it back some. DD told me I can make the right head touch the firewall with their sliders.
The frame notch was done by me. I was told the frame is slightly wider on the 67 trucks and I had to notch it to get the stand to fit.
I think your stands are farther forward then mine about 1inch.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
all of the 63-70 frames are wider at the motor perches than say the 71/72 are. Maybe even up into the 70's further. all of the aftermarket perches require the frame to be notched or trimmed about an inch or so to fit. POL, ECE, all need frame notches
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I have the same kit. But I didn't have to cut or trim anything. It is in a 70.
#13 |
Dirty Dingo Sliders & never look back
#14 |
I don't believe that the DD sliders will work with the ece mounts.
#15 |
#16 |
Lol They will with a little fab work & they give you front and rear adjustability
![]() I mean in the early 90s that's what they used to say about LS swaps into classics. OK being serious now I was commenting on another post and somehow got mixed up with this post but look up Ironworks Speed & Kustoms they make a nice mounting bracket it's amazing I haven't seen them more on these trucks it's a real nice set up the one that you want is the LS1 bracket fits like a glove & you can mount it just about anywhere I mounted mine on the driversside between brake booster & hood hinge looks almost like the factory put it there. I hope this helps |
