Old 08-24-2015, 09:54 PM   #1
revjames
Front coil springs
I have a 63 c10 that I upgraded to an 85 front crossmember. I bought djm lowering control arms for the front. So far everything is working I just have a question issue with the front coil springs. They are not siting fully against the lower control arm. If just half of the bottom of the spring is I. The control arm is that okay?? Thanks for the help
revjames is offline   Reply With Quote
Old 08-24-2015, 09:55 PM   #2
revjames
Re: Front coil springs
Here is another pic
Old 08-25-2015, 07:03 AM   #3
PGSigns
PGSigns's Avatar
Looks like there is no weight on them yet. Once you put the weight back on the suspension it will look like it should.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-28-2015, 12:07 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: Front coil springs
Originally Posted by revjames View Post
Here is another pic
Be sure when you install them, with slightest pressure to hold them in, that you spin the spring clockwise until its bottom "end" is snugly against the bottom 'locator'.
Sam
luvbowties is offline   Reply With Quote
