Need a new battery for my 72K5
What is the best truck battery I don't want the best warranty I want the one that most likely wont need the warranty.
What do you suggest cost no significant object. Thanks PG |
Re: Need a new battery for my 72K5
If you want a stock appearing battery I don't know. I run an Optima Yellow top, which is a deep cycle bat. Mine sits for long periods of time. Have had it now for a couple of years and starts up every time.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
I run 2 deep cycle marine batteries and use a marine battery switch to control the setup. I can have only Batt 1, only Batt 2, Both Batts 1 & 2, or totally off.
72 K5 Blazer - BCHWGN |
Odyssey and Deka are highly regarded.
www.odysseybattery.com/extreme_batteries.aspx www.dekacatalog.com Kinetic and XS are two more top, but lesser known brands. Ive had more good luck than bad with Optima's, once I switched away from the red tops over to the yellow and blue tops. |
![]() Join Date: May 2013
I had an odessey in my chevelle , it cured some issues I was having , I highly recommend them
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
