Old 08-25-2015, 06:26 PM   #1
CST10
CST10's Avatar
Alternator Wiring Guru Help Needed.
Ok, my alternator went out yesterday on my 1970 C10. I ordered a new high 150 amp alternator from powermaster. I can't seem to find an answer on the website or here so.......it's going to be a 3 wire hook up with the sensing wire.
I ordered the alternator to battery larger 6 gauge cable at the same time.
Do I hook this wire to the current battery junction box on the firewall that the old system used with the fusible linkage? Or go straight to the battery?
Do I need to upgrade the fusible link? If I go straight to the battery, what would I use as overprotection so I don't blow up the battery or some crazy stuff?
Anything else I'm missing?
What about ground cable systems?
Anybody have some diagram?
Don't wanna fry the truck down.
Thanks.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 08-25-2015, 06:54 PM   #2
Hogshooter
Re: Alternator Wiring Guru Help Needed.
http://www.madelectrical.com/electrical-tech.shtml here is a link that should help, I used their diagram for my truck and it works great.
Hogshooter is offline   Reply With Quote
Old 08-25-2015, 10:31 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Question is, do you have the 7 gauge dash or the 3 gauge with the charging light? If it's the 7 gauge do you want the ammeter to work?
You only need enough power to keep the battery charged so you don't need a big huge cable or a large fusible link 40 amp is plenty. Everybody seems to think that the battery supplies all the power to the truck and the alternator just recharges the battery. In fact the alternator runs everything and recharges the battery. The battery just starts the truck and supplies emergency power if the alternator fails.
You'll need a junction block to run the 6 gauge wire to ( I used 8 gauge ) and the sensing wire. The exciter wire from the alternator must run to the key switch through a 10 ohm resistor wire which you should already have from the key switch to the firewall block. It will exit the firewall block on the engine side as a 16 gauge brown wire, which ran to the old external regulator.
Battery negative to engine block. Engine block to front frame, and one to cab. You should have a ground from the neg cable to the radiator support shroud for the front lights. 10 or 8 gauge. Then the back bed to frame ground, and make sure the fuel tank is grounded. Inside the cab the dash
must be grounded to the instrument cluster. And the wiper motor must be grounded to the cab. Anywhere else you want you really can't have too many grounds. There is a grounding diagram somewhere, I'll see if I can find it.
I like this one.
Name:  alternator battery junction Wiring2.jpg
Thanks.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-26-2015, 10:40 AM   #4
CST10
CST10's Avatar
I have a 7 gauge cluster but no amp meter. I have an aftermarket volt meter.
Where did you get your junction block from?
Yes. If you have a drawing with the ground connections that will help also.
MyToys:
Old 08-26-2015, 10:50 AM   #5
OregonNed
OregonNed's Avatar
I purchased and installed a power master myself, and their email support was awesome if that helps too.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-26-2015, 06:24 PM   #6
CST10
CST10's Avatar
Good info to know about their customer support.
MyToys:
Old 08-26-2015, 09:11 PM   #7
swamp rat
swamp rat's Avatar
150 amp? Holey smokes thats a lotta amps! I never needed more than 90 (ish)
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-26-2015, 09:31 PM   #8
hardwaycooke
hardwaycooke's Avatar
Originally Posted by VetteVet View Post
VETTEVET IS THE MAN!!!!!!!!!!!!!!!!!!!!!!!!!!! Come and see me!!!!!!!!!!!!!!!!!!!!!!!!
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 08-27-2015, 04:49 PM   #9
CST10
CST10's Avatar
With 2 big electric fans, electric fuel pump, vintage ac, stereo, and headlights all on at an idle things start to slow down and the voltage dropped to 11 on the gauge.
So the 100 amp alternator barely kept up, I figured I'd go the next one higher. The techs at powermaster said at an idle with all that I needed around 80 amp. A 100 amp alternator only put out about 70 at idle. I drive in heavy traffic at a slow pace sometimes. They recommended the 140-150 alternator.
MyToys:
Old 08-27-2015, 08:12 PM   #10
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
